Triton Routers has changed their line up. Anyone have thoughts about them?
Forum topic by Douglas Bordner posted 445 days ago 1363 views 0 times favorited 15 replies Add to Favorites Watch
Douglas Bordner
3907 posts in 2233 days
445 days ago
Topic tags/keywords: router question
Sadly my PC 690 is getting a bit weary after 14 years hanging under the table in the garage.
Tell me what you know about Triton’s line up, old or new from your own perspective as an owner.
Conversely, if you think they suck, and have a non-Festool, non router-motor/separate lift table favorite, I’m all ears. I’d like to go a minimum of 2HP or equivalent.
Thanks Lumberjocks for your time and thoughts on the matter.
15 replies so far
View jdmaher's profile
jdmaher
175 posts in 749 days
#1 posted 445 days ago
I’ve had the MOF001 in a router table for about a year. Plenty powerful for my needs, and all adjustments happen above table.
It IS a little awkward, but its probably just me. I’m nit-picking here.
1. To get the height winder forward of the fence, the switch winds up at the back of the table. When you raise the bit to lock the collet, the switch turns off, and a little door slides over the switch. Very safe, but awkward to turn back on.
2. To change bits you have to raise the bit to lock the collet. If I’m doing rails and stiles, this is (sometimes) exactly what I do NOT want to do. Again, not a deal-breaker, but it would be even nicer to be able to change bits without changing height setting (that is, an alternate collet lock).
I think that to get everything I’d really like, I’d need to get me an electronic, digital lift – rather than a built-in, above table height changer. Well, if I ever win the lottery and there’s any money left over after payiing off bills – I’m probably still too “frugal” to ever buy such a thing anyway.
Triton’s a very good router (best of the 5 that I own).
-- Jim Maher, Illinois
Douglas Bordner
#2 posted 445 days ago
Thanks. Jim. I’ve only got three, including a Dremel on Stew-Mac’s base and a PC trimmer. If I hit the lotto I’d like a bunch more. That little DeWalt plunge looks sweet, and then if I got the Powerball—Festool.
View Greg The Cajun Box Sculptor's profile
3777 posts in 1478 days
#3 posted 444 days ago
I have been using a Bosch 1617 router in my table for over 4 years and it is a workhorse and I am very satisfied with it. I also have a PC 7815 router hooked to another router lift plate that I can put in the table if I need more power for raised panels but it seldom gets used.
I have a Triton plunge router i bought onsale about 6 months ago but it have never seen any use yet so I can’t say much about it.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
Douglas Bordner
#4 posted 444 days ago
Thanks, Greg. Good to “see” you.
6499 posts in 2149 days
#5 posted 444 days ago
Hi Doug,
You may as well save your money on the power ball…I’m gonna win it! but I’ll buy you a nice Festool router.
lol
View cajunpen's profile (online now)
cajunpen
11545 posts in 2235 days
#6 posted 444 days ago
That’s funny Lee, because I thought I had the winner in my sights.
34370 posts in 2570 days
#7 posted 444 days ago
Douglas: I had a Ryobi in my Router table and the bearing started to go and after running for a while I could smell Electric smoke. Turn it off and wait awhile and I was good to go for a while.
I finally decided to swap it out. I bought a Hitachi at Big Blue for a very reasonable price. I’ve got a raiser as part of my router lift so I don’t do it as part of the router. It seems to be working fine but it’s less than 1 year old.
View buffalosean's profile
buffalosean
174 posts in 1556 days
#8 posted 444 days ago
I have had three bosch 1617evs. Very comfortable to use. however, I burned one out in a year. Another, still works after two years, but he bushings are going to need to be replaced. The third one works perfectly, oddly enough, it is the one that I have abused the most and had for almost 4 years now. Its a shame I’ve had varying results from this. I liked the first one so much I went out and purchased two more. Unfortunately, that did not work out so well.
I have a freud 2200 plunge router. This thing is a beast. IT is heavy and slightly awkward to use, however, it is more than powerful enough for almost every application. Changing out bits and the on/off switch location are two of my favorite features.
I’ve used the porter cable 690’s. They are nice and versatile for light to medium duty routing. To be honest, I wish I bought a pair of those, rather than the last two bunk bosch routers I picked up.
Hope that helps you with your decision douglas. Good luck & Happy woodworking
-- There are many ways to skin a cat...... but, the butter knife is not recommended
17840 posts in 2020 days
#9 posted 444 days ago
Doug, I’ve had a ‘Makita’ for many years. Has not missed a beat. Very tough & durable. Worth the extra dollars.
Good luck in whatever you choose.
Dick, & Barb Cain
8681 posts in 2469 days
#10 posted 444 days ago
I have an 3 HP Triton. I’ve had trouble with dust gumming up the rack & pinion. I’ve cleaned it out once, but it’s starting to work hard again, so I guess I’ll have to clean it again. I think I’ll remove it as my table router, because its a pain cleaning it. I don’t know how the dust gets in there. It seems to be a design flaw.
View HorizontalMike's profile
HorizontalMike
4931 posts in 1083 days
#11 posted 444 days ago
I have the two larger Tritons and have both mounted. The 3 1/4hp model is in my router table extension of my TS and the 2 1/4hp model is in my horizontal mortising machine. Both work as designed, though I do NOT care for the stock 1 1/4in dust hose as it is worthless. The routers themselves work very well, especially after Triton upgraded their worm gear from plastic to metal. I reviewed that upgrade here.
Douglas Bordner
#12 posted 444 days ago
Mike that was one of my fears, so thanks for that!! Thanks for the excellent links.
If they have an on-shore presence in the US that is even better – that was a second concern.
I wish Woodcraft had them on-sale today.
HorizontalMike
#13 posted 444 days ago
Doug,
I was able to build a very efficient dust collection system into my horizontal mortising machine (in the neighborhood of 90-95%). Knowing this, I would imagine that could also be done on any shop-built router table. Having one of my routers hanging under a cast iron extension, a good DC system for that would take some extra thought for the underside of the extension. The router fence DC on my router extension does work well though. A rough estimate of overall dust control on that router would be in the ~60-70% range.
Douglas Bordner
#14 posted 444 days ago
Thanks all! Dick and grumpy especially nice to see you!
Went with the 3.5 Triton – which was on sale at Woodcraft after all.
#15 posted 444 days ago
Good luck with the new toy Doughie.
