Delta scroll saw
Forum topic by danz posted 03-03-2012 01:55 PM 898 views 0 times favorited 1 reply Add to Favorites Watch
View danz's profile
danz
3 posts in 2335 days
03-03-2012 01:55 PM
Topic tags/keywords: scroll saw
I have a Delta 40-690 scroll saw, it is a year old and I’m having trouble keeping the blade tit. I switched the top and bottom thumbscrews around and that did nothing. then I removed/switched the set screws that the thumbscrews tighten into to and the blade still comes loose. Any ideas on what to do?
Dan
—danz,IL,http://.woodworkersdanz.com
-- danz,IL,http://.woodworkersdanz.com
1 reply so far
View MrsN's profile
MrsN
986 posts in 3527 days
#1 posted 03-03-2012 02:19 PM
Do you clean the blades? They have oil residue from manufacturing. Use some mineral spirits on a sponge or rag. Some times you also have to clean the set screws as well. If the screws have been well used they might get rounded over or a groove set in. Try sanding (or grinding) the screw flat again, but make sure it really is straight or you will get more problems. You can also replace the screws if needed.
