problems adding an extension block kit to a 14" band saw
Forum topic by Jeremiah posted 03-03-2012 02:35 AM 792 views 0 times favorited 0 replies Add to Favorites Watch
View Jeremiah's profile
Jeremiah
2 posts in 3055 days
03-03-2012 02:35 AM
I recently got the kit to raise my Shop Fox 14” Band saw but I’m having trouble getting the guide post out. The instructions indicate that I should loosen it and then put the new extended guide post in from above while lowering the old guide post out. The problem is that once it gets to its lowest point the old guide post just stops and wont go lower than level with the assembly (with all the screws being loosened). I am rather new to this band saw so its probably a newbie mistake, but I figured I would post here while waiting for Shop Fox to get back to me. Thought maybe someone who owned the same band saw might already know the answer.
Thank you for any reply,
Jeremy
0 replies so far
