Getting Started in woodworking
Forum topic by bandit posted 03-03-2012 01:18 AM 1743 views 1 time favorited 23 replies Add to Favorites Watch
View bandit's profile
bandit
25 posts in 2273 days
03-03-2012 01:18 AM
Topic tags/keywords: new woodworking question
I’m very new to woodworking and would like all the advice I can get on getting started and what’sneeded to set up a really good shop.
-- Michael Garrett
23 replies so far
13603 posts in 3337 days
#1 posted 03-03-2012 01:34 AM
what tipe of woodworking are you thinking
power or hand
and how big a shop do you have available now
and hope to set up
garage
basement
or stand alone
how much power does it have
ventilation
light
and access
all this will help us help you
welcome to LJ’s !
View FreshSawDust's profile
FreshSawDust
68 posts in 2326 days
#2 posted 03-03-2012 01:38 AM
Such a loaded question. If you are looking for advice this is a great place to get it but a lot of what you are asking depends on what you would like to do. What kind of projects do yo think you would like to do?
-- TJ - Perryville, Missouri
View oxyoke's profile
oxyoke
57 posts in 2350 days
#3 posted 03-03-2012 01:48 AM
Hello bandit; To give you better advice it would be nice to know what tools you already have.I would start building with the tools you have and ad more tools as you find them necessary.
-- Bill Byron Center MI
View JAAune's profile
JAAune
1798 posts in 2313 days
#4 posted 03-03-2012 01:51 AM
Hmm. Until I know more, I’d recommend acquiring decent chisels and layout tools (marking gauge, x-acto knife and a machinist combination square). Unless you’re doing wood-turning those are pretty much needed for any type of woodworking.
View BentheViking's profile
BentheViking
1782 posts in 2560 days
#5 posted 03-03-2012 02:19 AM
Read this book
-- It's made of wood. Real sturdy.--Chubbs Peterson
View okwoodshop's profile
okwoodshop
448 posts in 3171 days
#6 posted 03-03-2012 02:22 AM
MONEY, lots and lots of MONEY
oxyoke
#7 posted 03-03-2012 02:26 AM
Awesome book I bought it 3 years ago
117090 posts in 3573 days
#8 posted 03-03-2012 02:39 AM
Hi Michael
Welcome to Ljs
That question has been asked very often ,I would suggest doing a search here on Ljs.
View bhack's profile
bhack
349 posts in 3717 days
#9 posted 03-03-2012 02:53 AM
BentheViking’s suggestion is great. Try the step stool or bench. They were my initiation into woodworking. Get some pine from Lowes or Home Depot and go at it. I built those with a circular saw and a cheap jigsaw. You will need to know what you need and want from there. Welcome to the site.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
View doncutlip's profile
doncutlip
2832 posts in 3552 days
#10 posted 03-03-2012 03:04 AM
Start simple. Buy just what you need. I started with a circular saw and saw horses. As you progress you’ll realize how bad store bought lumber is, so you’ll need a way to dimension lumber. That means a planer and a jointer. Then you’ll debate between a bandsaw and a table saw, your choice. And the list goes on and on, but a router sure is handy (and you’ll want a router table for it), sanders (sheet, random orbit, belt), sanding station, drill press, etc. And don’t forget dust collection. Finally every shop should have a good sturdy workbench or assembly table. Good luck starting out, whatever you buy always put safety first – accidents happen fast.
-- Don, Royersford, PA
View Viking's profile
Viking
880 posts in 3192 days
#11 posted 03-03-2012 03:11 AM
Bandit;
You asked a question that is almost unanswerable. Suggest you spend time just wandering around this site with the search function which should help you to craft topic specific questions.
The LJ site is loaded with great information that you might learn from.
Welcome to Lumber Jocks!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
bandit
#12 posted 03-03-2012 03:57 AM
So far I have a 10” Craftman Table Saw, 10” Compound sliding Miter Saw, Vertical Panel Saw, Drill Press. I have to set up my 2 car garage with cabinets and benches.
-- Michael Garrett
#13 posted 03-03-2012 04:21 AM
here is the hand tools questions and some good answers
http://lumberjocks.com/topics/10006
not everything
but some of the basics
to be added to as you go
like some here have said
you will know what to get as you need them
View DIYaholic's profile
DIYaholic
19620 posts in 2671 days
#14 posted 03-03-2012 05:19 AM
Welcome to LJs, a nice slice of insanity!!!
You will need a Psychiatrist, Banker, Pharmacologist, Electrician, Sawyer…...........
View thedude50's profile
thedude50
3603 posts in 2474 days
#15 posted 03-03-2012 06:16 AM
I wonder if the writer is going to read this so many times these vague questions are never revisited. The first thing you need to do is ask your self the questions Patron asked you what kind of shop do you want and how big is your workspace. if you are confined to a very small space a had tool shop will serve you best if you are lucky and have a barn the size of a small basketball court then you may want to go the power tool route or you may opt for hand tools because they let you work the wood and there is less dust and less noise or maybe you watched Norm Abram and want to have a new Yankee Workshop in your basement . the reason you need to decide is clear you can do everything with out power tools but most woodworkers these days are of the Hybridized type they use both hand and power tools why its faster and lets you get the work done what is best well ask a hundred woodworkers you will get similar reply’s however no two will be exactly alike nor should they be which ever way you go you will need saws to cut planes and jointers to flatten and drills to bore holes there are tons of little tools that will make life easier and i agree buy them when you need them unless you have Obama’s budget you will want to only buy what you need if you don’t need it to finish the job save your money for a better saw wither it be a table saw or a disston hand saw if you want to learn allot about woodworking join rob cosmans site and they are going to be building a bench this next month no mater what kind of woodworking you are going to do you need a bench good luck
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
