My Dust Collector Setup
Forum topic by MrRon posted 03-02-2012 08:32 PM 1517 views 0 times favorited 5 replies Add to Favorites Watch
View MrRon's profile (online now)
MrRon
4720 posts in 3211 days
03-02-2012 08:32 PM
Here is a sketch of how I want to locate my DC. Note that it is mounted over 8’ above the floor, hanging from the roof rafters. The hose from the saw, etc will go to a pre-chip separator before going to the DC. Only fine dust will be blown out into the ourside. I live in a rural area, so dust won’t be a problem. The only question I have is; will the location of the DC affect the CFM and ability to collect chips. My reason for the DC location was to eliminate as much ducting as possible. [Too much duct, too much friction, hence lower velocity, right?]
5 replies so far
View pintodeluxe's profile
pintodeluxe
5623 posts in 2781 days
#1 posted 03-02-2012 09:13 PM
How do you plan to collect the fine dust? I have been intriqued by bagless systems, but most I have seen shoot the dust into a dumpster or garbage can.
Thanks
MrRon
#2 posted 03-02-2012 09:53 PM
I don’t plan to collect the fine dust. I just will blow it to the four winds. Since I live in a rural area [no neighbors], no problem. If you have to collect the dust, direct the exhaust down into a barrel.
4954 posts in 2461 days
#3 posted 03-02-2012 10:29 PM
Ron, I think you will be fine. Resistance to flow (static pressure) does increase with the length in the ducting so this should work to your advantage. Not having the filter will also increase air flow. Be sure to check your motor amps to insure your overloading it.
View Scot's profile
Scot
344 posts in 3364 days
#4 posted 03-03-2012 04:47 AM
A cyclone separator will catch the fine dust too
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
MrRon
#5 posted 03-03-2012 03:23 PM
Costs money. I already have all the other parts needed.
