Mobile tools question
Forum topic by justholler posted 03-02-2012 06:34 PM 1005 views 0 times favorited 4 replies Add to Favorites Watch
View justholler's profile
justholler
62 posts in 2292 days
03-02-2012 06:34 PM
Topic tags/keywords: mobile tools casters
As seen in the pics, I have a Delta planer with legs but no mobility. I would like to know if putting casters on this style of leg would create a problem or if this is a no brainer. I sort of feel like this is a dumb question but the particular piece of the leg has only a plastic type “foot” on it that obviously has a hole in it just right for a caster with stem. I wanted to go ahead and get another opinion if this foot is OK to use with a caster or if I should plan to go another route with making the machine mobile. By the way….what makes these things so darn heavy! It looks lighter than it is :-)
-- Of all the things I've lost, I miss my mind the most..... Twain
View Chipy's profile
Chipy
374 posts in 2563 days
#1 posted 03-02-2012 06:55 PM
I have a stand vary similar to this one and the casters just twist off because there is nothing to hold the molded leg bottoms.I suggest attaching the legs to a piece of plwood and then attaching the casters to the plywood.The other alternative is to get a Shop fox or HTC mobile base they are both are well made.http://www.grizzly.com/products/Mini-Mobile-Base/G8683Z http://www.htcproductsinc.com/mb.html
View peterbb's profile
peterbb
37 posts in 2257 days
#2 posted 03-02-2012 10:22 PM
I made an open frame of 1×4s. In one case, I sandwiched the foot of the legs between the two boards, and in the other I put one of the caster mounting bolts through the foot. However, I don’t know if either of these methods will work for you, as you don’t seem to have any horizontal metal at the base of the legs.
-- Peter
View MrRon's profile
MrRon
4722 posts in 3213 days
#3 posted 03-03-2012 04:34 PM
I too agree with Chipy on adding a plywood base. Small casters can fall off when rolling over a rough concrete floor. A frame made of steel angles and welded to the legs would be better if you have the capability.
View Russ's profile
Russ
357 posts in 3047 days
#4 posted 03-05-2012 08:32 PM
I have a cast iron router table with the same lame feet. this weekend I put 2×4 all around the perimeter on their side attached to 1/2” OSB then attached total lock casters to it. Similar idea to Peters but creates a little shelf which was a bonus.
-- Russ
