Decorative cedar raised beds
Forum topic by WooDR67 posted 03-02-2012 05:34 AM 1206 views 0 times favorited 1 reply Add to Favorites Watch
View WooDR67's profile
WooDR67
74 posts in 2281 days
03-02-2012 05:34 AM
Topic tags/keywords: cedar raised beds square foot gardening joining garden box
I am building my wife a “decorative” 4’x8’ raised bed out of cedar. I was simply going to frame it with 2×4s and then nail the 5/8” x5 1/2”x 18” to the inside of the frame. Then I got the idea to cut a 5/8”x 1.5”channel through the 2×4 and slide the cedar board into the 2×4 ( top and bottom). Do you think that the cedar will hold together strongly enough to support the weight of the bed and what is the strongest way to join the sides. I hadn’t planned on using any vertical 2×4 and all of the cedar board will be installed vertically (like paneling) Also do not currently have a dado blade setup so the dado’s will be done with my rip blade, the blade is a few weeks old Im worried that it will dull the blade quickly. Thanks for the advise Eric
-- "It is amazing what you can accomplish when you dont care who gets the credit"
1 reply so far
View Pete_Jud's profile
Pete_Jud
424 posts in 3721 days
#1 posted 03-02-2012 10:16 AM
I have made a dozen of those, make sure that you use galvanized screws. Don’t need to rabbit, simple butt joint with 3 -4 inch screws, pre drill, and you should be good to go
-- Life is to short to own an ugly boat.
