Sharpening planes & lathe tools
Forum topic by Edwin posted 02-29-2012 05:17 PM 1230 views 0 times favorited 7 replies Add to Favorites Watch
View Edwin's profile
Edwin
135 posts in 2906 days
02-29-2012 05:17 PM
Topic tags/keywords: sharpening
For the life of me I can’t get the knack of sharpening a plane iron or a lathe gouge.Does
Anybody have a good source for sharpening these???? thanks… Ed
-- Ed Port Republic
7 replies so far
View hhhopks's profile
hhhopks
650 posts in 2286 days
#1 posted 02-29-2012 06:06 PM
It should be all over here on LJ. Just do a search.
-- I'll be a woodworker when I grow up. HHHOPKS
View Willeh's profile
Willeh
228 posts in 2247 days
#2 posted 02-29-2012 06:11 PM
Have a view of this video:
http://www.youtube.com/watch?v=Rvop_JCfZGI
You dont need the same stones that he uses, you can apply that to anything. (Sandpaper on a piece of plate glass works just as well..
-- Will, Ontario Canada. "I can do fast, cheap and good, but you can only pick two... "
View lew's profile
lew
11946 posts in 3664 days
#3 posted 02-29-2012 07:36 PM
Same problem here. Bought a Tormek from http://www.sharptoolsusa.com/ (Farris Machinery)- when they were affordable- solved my problems.
View Don W's profile
Don W
18606 posts in 2476 days
#4 posted 02-29-2012 07:51 PM
sharpening section here
Don W
#5 posted 02-29-2012 08:46 PM
it might help to describe the process you are using now. And what’s not happening.
There are so many ways of sharpening. I did a blog a while ago. My technique is pretty basic.
Hollow grind with an aluminum oxide wheel.
Make sure its straight and you get a back burr.
MAKE SURE YOU FLATTEN THE BACK OF THE IRON.
Set the iron in a cheap eclipse type jig
Hit a fine stone
Hit the back of the iron
Hit the stone again
Never hit the back of the iron last.
Strop if desired.
Hollow grinding isn’t required, but I think it makes it easier when you’re learning.
View Bill White's profile
Bill White
4862 posts in 3869 days
#6 posted 02-29-2012 09:24 PM
There is a master’s degree somewhere on sharpening. Everyone has a different idea. Google woodworking tools sharpening. You’ll find more than ya ever want to know. Then, decide what equipment you have/want and go after it.
I have the stupid bench grinder and a Makita horizontal waterstone system. My tools are so sharp that I’ve bought some Kevlar gloves to keep me from killin’ my fingers while I’m workin’ on the tools.
Bill
-- bill@magraphics.us
View NJWiliam's profile
NJWiliam
32 posts in 2476 days
#7 posted 02-29-2012 09:26 PM
Paul Sellers has videos of his sharpening that is both fast and straightforward.
