Table Top construction
Forum topic by Freund posted 02-29-2012 04:12 PM 1859 views 0 times favorited 6 replies Add to Favorites Watch
View Freund's profile
Freund
4 posts in 2279 days
02-29-2012 04:12 PM
Topic tags/keywords: question
I am building a huge expanding dtable from 1/4 sawn Oak.
I am concerned about expansion in the top.
I am planning to make the top 7/8 thick, with a band that will enclose the edge.
tounge and groove jointed
On the edge, I was thinking of running 3/8 dowels through the end.
Should the edge banding be touge and grove as well?
I have seen tables like this, but am unsure how they keep them from moving etc
see attached drawing
-- Karl Freund, http://www.carpentryinnovations.org
View Loren's profile
10401 posts in 3648 days
#1 posted 02-29-2012 04:16 PM
Wood always moves.
(Solid wood does anyway.)
The current style is to make table tops flat. Antiques sometimes
have frame and panel tops. The problem is crumbs get caught in
the grooves.
One way to control it and make the top flat and flush is to use
“veneers” up to 1/4” thick over MDF or solid wood with the
grain running the other way.
Freund
#2 posted 02-29-2012 04:32 PM
So on the frame and panel, solid
Do I just glue up the interior panel, then make the frame 1/8 larger to allow for movement? And make that joint a tounge and grove as well.
Agian, this is 1/4 sawn Oak.
Veneer does not meet the design criteria
404 - Not Found
2544 posts in 2969 days
#3 posted 02-29-2012 04:40 PM
I made a similar table last year.
http://lumberjocks.com/projects/55523
I veneered it using 2.5mm veneers top and bottom. I didn’t want to veneer it, but it was the only way to avoid movement.
If it really has to be solid, I would make it without the frame and just leave the edges as end grain.
#4 posted 02-29-2012 04:50 PM
Well, you look at the width of the panel and look up
the movement coefficient per 12” width of the
wood species you are using, measure the moisture
content of the stock and calculate the amount of
width travel the panel needs to make and cut the
t&g joints accordingly.
Freund
#5 posted 02-29-2012 09:50 PM
Thank you for your valuable input. I have used different wood movement estimators that are on the avaliable on the internet. I have not found one that specifically addresses 1/4 sawn Red Oak .
#6 posted 02-29-2012 09:56 PM
