Transporting Rough Cut Lumber in Rain
Forum topic by grimesbum posted 02-29-2012 01:18 PM 6282 views 0 times favorited 22 replies Add to Favorites Watch
View grimesbum's profile
grimesbum
7 posts in 2318 days
02-29-2012 01:18 PM
Hi,
I’ve searched the forums here for the answer to my question & haven’t found it yet. I am pretty new to woodworking & am planning on picking up a couple hundred bdf of rough cut lumber this Saturday. It is supposed to rain pretty hard & I will be hauling the wood in the rain for about 1.5 hours. Will this damage the wood or will it dry out just fine when I get it home? I am assuming it will dry just fine but you know what they say when you assume…..
Thanks & sorry for the newbie question.
-Chris
22 replies so far
View MedicKen's profile
MedicKen
1615 posts in 3463 days
#1 posted 02-29-2012 01:36 PM
When you say rough cut, freshly cut or cut and dried?
If it still wet, just let it ride it out, its gonna take some time to dry out anyway. If it is air or kiln dried I would elevate it off the trailer or truck bed on 4×4’s, stack it just like you found it with stickers between the boards and cover it with a tarp or plastic. I think the best solution would be to use an enclosed trailer then all of the headaches of the rain are a non issue
grimesbum
#2 posted 02-29-2012 03:56 PM
It is cut & dried. Been stored in a barn for years. They are 10-ft boards so in the past I would push them all the way forward & then lean one end on the top of the tailgate with the tailgate closed.
View interpim's profile
interpim
1170 posts in 3459 days
#3 posted 02-29-2012 04:01 PM
I saw a bag being discussed here a while back that would fit into a truck bed, and enclose your materials for transport. I don’t recall what it was called, but basically it was a tarp bag with a zipper at one end. I think you could get away with covering it with a tarp, as long as you elevate it a bit to keep the water that pools in the bed from sitting on the wood for to long.
Also, if you get the wood in a dry place fairly quickly, you shouldn’t have any issues with the wood once it completely dries out.
-- San Diego, CA
View Loren's profile
10403 posts in 3649 days
#4 posted 02-29-2012 04:02 PM
I would get it elevated and tarp it on principle, but
really there’s not much chance of damage. The wood
will get surface-wet if exposed but that will dry out
relatively quick.
Sustained exposure to wet/dry cycles of dry wood left
outdoors causes surface checking.
View Bill White's profile
Bill White
4932 posts in 3961 days
#5 posted 02-29-2012 04:07 PM
I was gonna say “DRIVE REALLY FAST”, but I won’t.
You’ll be ok. Just don’t let the wood get in any pooled water.
Are the ends sealed?
200 bf? That’s a bunch. Good haul (no pun there).
Bill
-- bill@magraphics.us
View dbray45's profile
dbray45
3320 posts in 2777 days
#6 posted 02-29-2012 04:11 PM
Let me think, its a tree.
What I do—-
If it is a wide open grain like red oak, I might put something over the end grain and tie it down. When you get it home, sticker it in the garage and run a dehumidifier until the water collection starts going down – about a week, depending upon how dry the wood is, maybe 2 weeks.
-- David in Damascus, MD
grimesbum
#7 posted 02-29-2012 04:21 PM
It is quartersawn white oak. I generally store it in my pole barn but I will plan on covering it with a tarp and if it does get wet I will just put it in my basement with a dehumidifier for a while. Thanks for the advice!
-Chris
404 - Not Found
2544 posts in 2970 days
#8 posted 02-29-2012 04:28 PM
Tarpaulin or collect it when it’s not raining.
I just wouldn’t take a chance on it getting water stained.
dbray45
#9 posted 02-29-2012 04:28 PM
White oak is water proof – all is good
I still dry everything a week or two after I get it anyway – it is also harder to dry in the first palce
View poopiekat's profile
poopiekat
4355 posts in 3735 days
#10 posted 02-29-2012 10:43 PM
As much as I hesitate to recommend this guy, he is a lumberjock and from time to time shamelessly self-promotes his wares. The Kerry-All pouch: http://www.kerrywoodworking.com/
View peterrum's profile
peterrum
153 posts in 2680 days
#11 posted 03-01-2012 01:02 PM
I have had to drive home 5 hours with kiln dried slabs in the back of my truck or trailer. I tarp them well, usually wrapping it completely around the wood, folding the ends over and duct tape the heck out of it. Duct tape is so wonderful…...lol
-- Carpe Diem
View Lilskip's profile
Lilskip
20 posts in 2279 days
#12 posted 03-01-2012 01:58 PM
I bring several hundred BF of lumber down from TN several times a year to SC, roughly 9h drive. Like the others said you can’t really beat a good tarp. I normally lay one down on the trailer and then stack it with stickers in between and then put another tarp over the top with straps and bungies to keep it tight so water doesn’t pool up. The only part I hate is unloading it when i get home. but I haven’t had a problem with doing it that way.
-- www.TinderBoxWoodworking.com
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#13 posted 03-01-2012 03:17 PM
I use a 10’ open trailer. Tarp laid down first, then stickers. Tarp is usually wide enough to wrap and cover. Lots of bungees, rope, and duct tape.
Just brought 300 bf from TN to AZ. Hit lot’s of rain but, it was dry when unloaded.
grimesbum
#14 posted 03-01-2012 03:19 PM
I appreciate all the comments guys, thank you. I will just tarp it well and hope for the best.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3481 days
#15 posted 03-01-2012 03:27 PM
I think you would be best to cover the wood with a tarp. I never try to haul wood in the rain or snow if I can help it. You always take the chance of having it warp, or even get stained. I got caught in a rain a few years ago hauling a piece of plywood. It only rained hard about 10 minutes. When I got home I hauled the wood into my shop, let it dry out and it had water stains on the surface that I just couldnt get out. I wondered if it was from the road spray.
-- Wayne - Plymouth MN
