100 year old work bench
« back to Coffee Lounge forum
Forum topic by pommy posted 126 days ago 263 views 0 times favorited 8 replies Add to Favorites
View pommy's profile
pommy
110 posts in 172 days
126 days ago
Topic tags/keywords: question tip
Hi alll
i have just purchased a appox 100 year old work bench and i have a question as you can imagine the joints are abit open does anyone have any ideas as to what i can do to close the joints as i would love to restore this beautifull bench when i can i will post a picture so you guys can see it
thanks
andy aka pommy
-- cut it saw it scrap it
View GaryK's profile
GaryK
8482 posts in 469 days
126 days ago
Usually if they are glued joints, you try to take them apart, clean them up and then re-glue them.
pommy
126 days ago
gary i must admit im scared of ruining the wood is there anyway of disolving the glue to make it easyer to pry apart
teenagewoodworker
2025 posts in 249 days
126 days ago
if it is old and you take apart the glue joints you might want to use structural epoxy to glue it back together because the joints will be loose and regular yellow glue might not work as well.
GaryK
126 days ago
If it’s 100 years old it’s probably hide glue. I forget what is used to soften it up. Try heat (hair dryer).
View tenontim's profile
tenontim
913 posts in 225 days
126 days ago
Vinegar will soften up hide glue.
-- Tim -- http://tmuli.com
View Damian Penney's profile
Damian Penney
672 posts in 472 days
126 days ago
Heat will definitely loosen the hide glue.
View bbqking's profile
bbqking
234 posts in 204 days
122 days ago
50/50 vinegar and water. Wait. bbqKing
-- bbqKing, Lawrenceville
5573 posts in 332 days
121 days ago
Lucky boy pommy. Wish I had your problem.
Bookmark And Share This Page
