Mitered shooting board not quite shooting...
Forum topic by gljacobs posted 02-28-2012 11:42 PM 1712 views 0 times favorited 4 replies Add to Favorites Watch
View gljacobs's profile
gljacobs
76 posts in 2865 days
02-28-2012 11:42 PM
Topic tags/keywords: jig question
I have a shooting board that I have recently attached a mitered section to….well, miter things.
The problem is it will inconsistently shoot miters and now I want to shoot thing but not with a board.
All puns aside I’m frustrated and would like to ask the kind pool of wisdom to reflect back some soothing knowledge.
The details :
I tuned the lil’ bugger in to 45 degrees and screwed it down very securely, repeat very securely.
I know movement isn’t the ‘cause I checked and double checked, then, because I have a problem, I checked again.
Onward.
I then shot a small test piece and it was inconsistent.
I check for square on the perpendicular face to the miter…and it was out. This told me that I was tipping the plane into the blade cut out that runs down the track. After correcting my technique I found that because the stop didn’t run all the way to the bottom of the plane sole the fibers weren’t backed up and this left a few lonely lil’ fibers at the very tip that impinging the progress of further cuts. The results….the plane ceased to cut. I cut the fibers with a block plane square and miraculously this allowed me to continue.
Update:
So I wrote this last night and then tried again today to understand my mistake/lack of understanding.
So I found that the board was slipping so I put some sticky sandpaper on it and this helped dramatically.
Next I had to tighten the cap iron down because the 1 3/4 thickness/girth of the board kept dragging the blade askew. This helped….I think the next step is moving the fence all the way out to the edge of the plane.
The last bit of info is that I have to extend the blade pretty far out(baffling) to even get a cut which with the board being an 1 3/4” thick is more difficult than just taking a shaving half the size.
Thanks in advance for an
View gerrym526's profile
gerrym526
274 posts in 3986 days
#1 posted 02-28-2012 11:51 PM
This may sound pretty basic, but when was the last time you sharpened your plane iron? the fact you have to extend the blade so much leads me to think you need to sharpen it.
Just my 2 cents.
-- Gerry
gljacobs
#2 posted 03-01-2012 12:51 AM
I just sharpened it a lil’ while ago and just touched it up to hair shaving sharp after my initial run(before update) and I’m still having inconsistent results.
Regardless I’m going to keep trying.
Thank you for your 2 cent always appreciated.
View Richard's profile
Richard
1922 posts in 2868 days
#3 posted 03-05-2012 08:49 PM
A photo or 2 of the setup might help someone that has more knowalege of them figure it out for you.
View AnthonyReed's profile
AnthonyReed
10041 posts in 2618 days
#4 posted 03-05-2012 09:26 PM
This helped me get my shooting board dialed in: http://www.inthewoodshop.com/ShopMadeTools/Setting%20Up%20and%20Using%20a%20Shooting%20Board4.html
Towards the bottom of the page there is some trouble shooting advice.
Best i got for you. I hope it helps.
-- ~Tony
