Need Insight
Forum topic by Drew posted 476 days ago 529 views 0 times favorited 6 replies Add to Favorites Watch
View Drew 's profile
Drew
328 posts in 887 days
476 days ago
Hey LJ’ers, I have recently built a two step platform for patients to stand on while getting their x-rays in my clinic I work for. The platform has a handrail used for balance on one side of the platform. During the build of this project I thought it would be a fine design but after the build was complete I am concerned about the handrail’s stability. The rail is made of two upright dowels (1 3/8” in diameter) that are 36 inches from the platforms upper step and run through the top of the platform and screwed to the inside of the carcase. The uprights are capped off with a mortised handrail that connects the two together. The instability concern comes from the give the dowels have when pulled or pushed on. What can I do to increase the stability of this rail so it is less likely to break?
-- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK
View peterbb's profile
peterbb
33 posts in 484 days
#1 posted 476 days ago
I think I’d use steel (or heavy aluminum) pipe instead of wood.
I’d also extend the base of the thing to the right – if someone leans on the rail they’re as likely to tip the whole thing as to break the posts (unless you have a lot of weight under the lower step).
-- Peter
View UltimateCarvercom's profile
UltimateCarvercom
9 posts in 484 days
#2 posted 476 days ago
I agree with the previous posts too. The dowel is just not strong enough. The client on the handrail has a huge mechanical advantage in making the dowel flex. You need material that will not flex, hence steel.
-- Steve Groeneweg, http//www.UltimateCarver.com
Drew
#3 posted 476 days ago
Since removing the dowel may be too difficult without damaging the carcase do you think a strip of steel run up the length of the dowels would help?
peterbb
#4 posted 476 days ago
Anything you add to strengthen the dowells must go right to the floor. If it just runs from the top of the step to the handrail, the dowells would likely break at the top of the step.
I’d suggest steel angle rather than a flat strip, as the angle will add strength in all directions – flat strip will only help in its wide dimension.
Also, as I mentioned in my first post, you need to extend the step to the right, otherwise a person leaning on the rail would tip the thing to the right (if the dowells didn’t break.) A panel against the wall, solidly attached to the steps, would probalby be sufficient.
-- Peter
View bondogaposis's profile
bondogaposis
1316 posts in 548 days
#5 posted 476 days ago
I’d go with square steel tubing.
-- Bondo Gaposis
89038 posts in 1774 days
#6 posted 476 days ago
If you install a “X” in the middle of the two uprights that will make it much stronger as far as racking is concerned.
you don’t say what kind of wood the uprights are made out of? the kind of wood you use will make a big difference strength wise.
