What's on your shop "To-Do" list?
Forum topic by Manitario posted 02-28-2012 07:20 PM 7182 views 2 times favorited 45 replies Add to Favorites Watch
View Manitario's profile
Manitario
2630 posts in 2878 days
02-28-2012 07:20 PM
It seems like every project I realize that I need to make a new jig or that my workshop could use some other sort of improvement to improve efficiency/safety/increase storage space etc. I’ve had a bunch of stuff to build for my new house, so the shop projects have been sorely neglected. Recently I made a list, of which I hope to tackle at least one shop project between each house project. What shop projects are on your list?
Here’s mine:
-cross cut sled for TS
-improve overhead DC for TS
-base for drill press with storage for drill bits/accessories
-new mobile base for planer
-hand tool cabinet
45 replies so far
View kaschimer's profile
kaschimer
89 posts in 2384 days
#1 posted 02-28-2012 07:43 PM
- Whatever my wife wants/needs ;)
- Fix and tune my bandsaw
- Tune my TS
- Crosscut sled for TS
- Tool bases to get everything off my bench
- CNC router
-- Steve, Michigan - "Every piece of work is a self portrait of the person who accomplished it - autograph your work with excellence!" - Author unknown
View Elizabeth's profile
Elizabeth
817 posts in 3138 days
#2 posted 02-28-2012 07:47 PM
I’ve just made a 220v extension cord for my table saw, which gets the cord out of the way of my miter sled. I’m also in the middle of getting shop humidity down to a reasonable level. Next up are:
- A log resawing jig for the bandsaw
- Finish up the last two metal runs of the dust system, to the spindle sander and the miter saw/router
- Long-term projects – I’d like to make a folding table saw outfeed table, a bandsaw outfeed table, and a dust collection hood for the miter saw.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3475 days
#3 posted 02-28-2012 07:49 PM
I am currently building a maple hope chest. Once that is done (about 30 days to go) here is the list.
-Fishing rod rack
-King size mission bed
-Mission chest of drawers
-Mission night stand
-12X14 storage shed in the back yard
-Foyer table
-- Wayne - Plymouth MN
View DS's profile
DS
2916 posts in 2415 days
#4 posted 02-28-2012 07:56 PM
I’m a bit scared to write out this list, but, I think it needs to be done. Great topic, btw.
- Insulate the overhead doors
- Circle jig for bandsaw
- plumb the DC hoses overhead
- add a lighting fixture to East end
- storage shelving above overhead door
- refurbish the assembly table
- rework router table storage (LH vs. RH at new location)
Hmmm… that wasn’t as bad as I thought it’d be. Whew!
View chrisstef's profile
chrisstef
17380 posts in 3001 days
#5 posted 02-28-2012 08:01 PM
assemble dust collector
hot rod dust collector
build mobile bases x6
hang air filtration
tune #6,7,78 handplanes
View cuttwice's profile
cuttwice
60 posts in 2680 days
#6 posted 02-28-2012 08:03 PM
Shop projects:
bench hook / shooting board
winding sticks
TS crosscut sled
DC installation
proper bench
flip-top planer base / assembly table
More storage cabinets
Non-shop projects:
potting bench
hanging planting boxes
Mission bedside tables
Mission queen bed
(Yikes! What am I doing sitting in front of the computer?!!???)
View crank49's profile
crank49
4030 posts in 2965 days
#7 posted 02-28-2012 08:04 PM
I’m building my shop so I have more “todos” than “dones”. And, due to a major reduction in pay after a period of unemployment it’s going real slow. But I’m working the list down.
1. Sheet storage cart with panel saw jig mounted on one side, my own design.
2. Miter saw work station.
3. Dust collector closet. To reduce noise.
4. Slat wall and brackets for storing lumber.
5. Clamp rack.
6. Tool storage board.
7. Router table with shop built lift, plans from “Shop Notes”
8. 16” Band saw, shop built, from “Woodgears” plans.
9. Drum sander, shop built, from my own design.
View Hoakie's profile
Hoakie
306 posts in 4030 days
#8 posted 02-28-2012 08:05 PM
@Manitario. I think my list is the exact same as yours
In addition I need to:
  • Build better workbench,
  • Redo my lathe tool storage,
  • Update grinder stand and storage
  • Drill press bit storage
  • Sandpaper storage
  • Build Thein separator
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
View dbhost's profile
dbhost
5708 posts in 3227 days
#9 posted 02-28-2012 08:33 PM
Just off the top of my head…
#1. Build a shed to store lawn and garden as well as shop items during the following projects. #2. Strip sheetrock from all non common walls and ceiling. Run subpanel and circuits, rerock and repaint. #3. Reframe for, and install heavier duty folding attic stairs. The 250lb rating scares me. Rerock and paint as needed. #4. Prep and apply epoxy floor coating. #5. Re-mount lumber rack, tool stacker, clamshell cabinets, and library cabinet. Add bridge shelf to top of clamshell cabinets so that the entire space end to end of both cabs and the space between will have an 18” deep shelf above it. #6. Build miter saw station along common wall, making sure the fence area clears the freezer that will have to be stored next to it. (Bargain I made with LOML…) #7. Re-design DC location, and ductwork to reduce the distance from DC to tools including side flipping the impeller housing / motor and putting the Thien under the impeller housing. Upsize to 6” duct. #8. Rolling sheet goods rack with clamp storage. #9. Box Joint jig. #10. Complete drum sander project. It’s slow going, but it’s going. #11. Build a full on table saw / router workstation for my BT3100, I am using BT3Central member jnesmith’s workstation as inspiration. #12. Rebuild / build a proper workbench. I found out a mess of things I don’t like about the design of the workbench I built and can’t wait to get started on a new one…
View Ripthorn's profile
Ripthorn
1458 posts in 2980 days
#10 posted 02-28-2012 08:34 PM
Mine is too long to put here, but the top items are: – Finish Thein separator – Tune up bandsaw – Start building a workbench – Finish the fliptop tool cart – Put in another fluorescent fixture over the TS
View DamnYankee's profile
DamnYankee
3301 posts in 2557 days
#11 posted 02-28-2012 08:38 PM
TS Cross Cut Sled
BS table
DP table
Rebuild workbench
Install shop drawers (I have them, they are ready to go, but installing includes previous item – rebuild bench)
-- Shameless - Winner of two Stumpy Nubs Awards
Manitario
#12 posted 02-28-2012 08:39 PM
Nice lists; it seems sometimes like we spend more time making stuff for the shop rather than making stuff with the shop! I keep thinking that I’ll reach a point where I’ll have all the tools I’ll need and all the jigs and shop projects complete, but I don’t think I’ll ever reach that point.
View Richard's profile
Richard
1916 posts in 2685 days
#13 posted 02-28-2012 08:47 PM
#1 on the Shop list is to find a place to have a real shop, even if it is tiny. working out of the carport is a pain when you have to haul everything out and then back inside when your done.
View barecycles's profile
barecycles
257 posts in 2323 days
#14 posted 02-28-2012 10:32 PM
Shop lights…Shop lights…SHOP LIGHTS!!!!!
Until I can see what I’m doing in the shop dungeon, I’d just be wasting my time working on anything else.
-- Sweeping up sawdust in Texas
View KMT's profile
KMT
603 posts in 2657 days
#15 posted 02-28-2012 11:18 PM
Well, I just finished a router table ( will post in projects soon).
Need an Air filtration unit.
We have the house up for sale so I am now working on installing the trim around the doors and windows in the shop. For some reason it bothers me that I didn’t finish it when I built the shop a couple years ago, so I want to see it completed.
I’m sure I have a long list of to do’s ahead of me at the next place (which I have told my wife MUST HAVE a shop) http://lumberjocks.com/KMTSilvitech/workshop
Other than that I can always find something to do to improve my enjoyment in my shop.
-- - Martin
showing 1 through 15 of 45 replies
