Any advice for removing stripped screws?
Forum topic by Kiersten posted 1843 days ago 1336 views 0 times favorited 14 replies Add to Favorites Watch
View Kiersten's profile
Kiersten
69 posts in 1850 days
1843 days ago
Topic tags/keywords: question
Hi all,
I just finished putting together my new table saw and stripped a screw on the blade plate cover so I can’t open it to change out the blade. Any suggestions? I’d rather not have to buy a Grabit as I need to cut some wood today.
Thanks for your help!
Kiersten
-- Kiersten, Los Angeles, http://www.modmomfurniture.com
14 replies so far
View Damian Penney's profile
Damian Penney
1140 posts in 2189 days
#1 posted 1843 days ago
You could grind a slot into it, and use a flat head screwdriver to get it out, kinda like I did here I ground the slot with a cutoff wheel on my Dremel.
Kiersten
#2 posted 1843 days ago
Thanks, Damian. I think I’ll go try that. And that is such a cool picture of you grinding a slot!
Damian Penney
#3 posted 1843 days ago
Hope it does the trick, so which table saw did you get? I’m scouting out a new one myself.
Kiersten
#4 posted 1843 days ago
After much research and a limited budget, I ended up with the same Craftsman – 10-inch portable with 30 inch rip capacity on the right (that’s important for what i cut) I ran into the ground over the past two years. I figured since I know its ins and outs and how to quickly set it up, it was the best thing given I have two orders due this week that I haven’t even started on. Ugh. I sell quite a bit of one particular toy box so for that one – Owyn—I have a CNC shop cut the pieces to save me time. The others I cut down from 4×8 plys. Is that too much information?
Damian Penney
#5 posted 1843 days ago
Too much information? No such thing :) I’m a big fan of CNC, if I was running a production shop I’d be all over it. Do you have a panel saw?
View Doug S.'s profile
Doug S.
295 posts in 1905 days
#6 posted 1843 days ago
Is there any way to get a needle nose style vise-grip plier on the backside of the screw and either finish screwing it all the thru or turning it back out enough to finish from the outside?
-- Use the fence Luke
Kiersten
#7 posted 1843 days ago
Thanks, Doug. I tried that but there’s not enough lip so there’s nothing for the pliers to grip. It’ll be ok. I just screwed it back in since it would work that way and prayed the blade was tight enough and went for it. Damn deadlines made me rush it.
View GMman's profile
GMman
3885 posts in 1895 days
#8 posted 1843 days ago
You can get and easyout tool
17955 posts in 2048 days
#9 posted 1843 days ago
Kiersten, you could take a photo to show the problem, as they say a picture takes the place of 1,000 words.
View mpwylie's profile
mpwylie
38 posts in 2166 days
#10 posted 1842 days ago
Right now Sears has there ease out 3 pc bits on sale for $10 bucks if you are a craftsmen club member. If not they are $15. Hope this helps. I think the sale ends on Sat 6/7/08.
-- Paul Wylie, Rogers, AR
Kiersten
#11 posted 1842 days ago
Thanks to all of you for your advice. I just went on ripping leaving the stripped screw in the blade cover plate completely avoiding it! I think I’ll head to Sears (thanks Paul) and get that Ease out 3 pc bit tomorrow. Turns out, I can’t find my slot grinder attachment for the Dremel because it’s lost somewhere in my crappy 1940s garage. Maybe one of the black widows carried it away.
View fredf's profile
fredf
495 posts in 1907 days
#12 posted 1842 days ago
some times you can use a small punch tangent to the head to spin it around, sounds like you had it loose. another trick is to use a drop of super glue to lock driver into the slot (espc for a cammed out philips, but should work on a slot also. I have also heard that dab of valve grinding compound will improve grip, the abrasive digs into the side of the slot and the screwdriver
Keep your screwdriver tips undamaged, A worn tip creates lotsa headaches!
-- Fred, Springfield, Ma
View odie's profile
odie
1675 posts in 2037 days
#13 posted 1814 days ago
OK, I can’t help it. Your picture and the word “stripped” all at once …. We are only human. Please refrain from doing that any more. Just kidding pretty lady number two ( there’s ONE prettier).
I just noticed, You’re from L.A. ... I grew up in Westchester, then moved to Hermosa Beach then to Redondo Beach. How close were you?
View Sac's profile
Sac
268 posts in 1831 days
#14 posted 1814 days ago
Just an FYI, I’ll usually take a small bit but yet big enough to pop the head off the screw and drill into the screw a bit more. Usually at that point I can either hammer (Tap) in a small flat head screw driver. It will usually punch the insides of the screw enough to turn it out. You may have to use some pliers to get a grip strong enough to turn it out but this process has always worked for me.
-- Jerry
