Dust collection suggestion
Forum topic by Josh posted 02-28-2012 01:48 AM 1237 views 0 times favorited 5 replies Add to Favorites Watch
View Josh's profile
Josh
36 posts in 2533 days
02-28-2012 01:48 AM
I have worked with wood all of my life but only recently had the opportunity to play with the real tools! I am getting my Sawstop 3 hp table saw this week, have a nice Dewalt 12” sliding, double bevel miter saw, and may eventually get a drill press, planer/jointer combo, and maybe even a lathe.
I know I need to do a dust collection system but know nothing about it. I obviously will be only working on one tool at a time and curious if anyone has any suggestions of specific systems that I should consider. I’ve heard the cyclone setup is optimal but just really need some guidance.
Thanks for any input.
-- Josh, Columbus, GA
5 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3152 days
#1 posted 02-28-2012 01:52 AM
Welcome to LJs Josh. Glad to have you on board. If you haven’t discovered it yet, LJs has a rather large number of posts concerning dust collection and much has been addressed multiple times. Try searching for dust collection and see what pops up. I think you will find a treasure trove of information awaiting you.
View Josh's profile
Josh
#2 posted 02-28-2012 01:53 AM
Will do…sorry for the redundant post…
View Grandpa's profile
Grandpa
3261 posts in 2913 days
#3 posted 02-28-2012 03:38 AM
Welcome to Lumber Jocks. Good to have you. As Mike said there are a number of threads on Duct Collection. They keep popping up because clean air in your shop is probably the most important thing in your shop. Bill Pendtz can be researched on the internet. He is probably the most knowledgeable man on dust collection systems. He had some dust related health issues and he did the research for us. The next thing you will ask after settling in on a collector is what to use for collection pipe. Plastic is far cheaper most of the time but static builds when using it. Then the argument goes to starting fires that have not yet happened in a home shop. Comfort from not being shocked is another matter. There are tons of things on here as well as some very nice baffles used to separate the particles instead of using the cyclone separator. Good luck in your research.
View Bobsboxes's profile
Bobsboxes
1369 posts in 2902 days
#4 posted 02-28-2012 03:45 AM
Welcome toLJ’s, lots and lots of info on dc’s.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View GPM's profile
GPM
26 posts in 3068 days
#5 posted 03-26-2012 01:35 AM
One suggestion – whatever your design or choices, have your system vent to the outdoors. There is no good system to filter the air and do it efficiently. All the other options are work arounds to not venting to the outside and they are all compromises in health and efficiency.
