Driving escutcheon pins
Forum topic by doninvegas posted 02-27-2012 10:37 PM 3317 views 0 times favorited 10 replies Add to Favorites Watch
View doninvegas's profile
doninvegas
334 posts in 2907 days
02-27-2012 10:37 PM
When I make some of my boxes I use small hasps that come with those little bitty nails or escutcheon pins. I use a pair of needle nose pliers and a small hammer to drive them. I’m not real good at this and was wondering if there is a better way. Is there just a thing as an escutcheon pin driver?
Thanks,
-- "Courage is being scared to death -- but saddling up anyway."
10 replies so far
View poopiekat's profile
poopiekat
4355 posts in 3734 days
#1 posted 02-27-2012 11:13 PM
I always toss ‘em , and used tiny brass screws with piloted holes. Much nicer result.
View bondogaposis's profile
bondogaposis
4727 posts in 2351 days
#2 posted 02-28-2012 01:13 AM
Cut the head off of one and chuck in your drill and pre-drill the nail hole. Works like a charm, unless they are real brass then you need to find a finish nail of the same diameter or slightly smaller, cut the head off and use it like a drill bit.
-- Bondo Gaposis
View sandhill's profile
sandhill
2128 posts in 3924 days
#3 posted 02-28-2012 01:35 AM
Well Don I think if you could find screws to use I would do that even if you had to up the size. You can get a 1/64th drill bit at any box store. You can also use a rare earth magnet as well to hold a nail nice and straight.
View Tootles's profile
Tootles
808 posts in 2502 days
#4 posted 02-28-2012 08:44 AM
Is your problem in the hammering home, or just in the starting of the nail? I ask because a neat trick for starting the nail is to hold it by pushing it through a strip of paper rather than using long-nose pliers. Once it is started, you simply rip the paper out.
-- I may have lost my marbles, but I still have my love of woodworking
View Danpaddles's profile
Danpaddles
573 posts in 2312 days
#5 posted 02-28-2012 12:33 PM
I have used my drill press as a press, (not while it is running-) to push in the pins, instead of pounding them in. I took a brass rod, about 1/4 inch dia., drilled a little dimple in the end of it. Chucked it up. Hold with your needle nose. Start pushing. Just need to have a few extras, the odd one will tip and bend after it is started.
-- Dan V. in Indy
View Don Johnson's profile (online now)
Don Johnson
685 posts in 2781 days
#6 posted 02-28-2012 02:58 PM
I’ve noted Danpaddles natty idea for future reference, but was the original question about something like this:
http://compare.ebay.co.uk/like/110760977749?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&adtype=pla
-- Don, Somerset UK, http://www.donjohnson24.co.uk
View Bill White's profile
Bill White
4932 posts in 3960 days
#7 posted 02-28-2012 03:23 PM
I always pre-drill, but not to full depth.
Bill
-- bill@magraphics.us
Danpaddles
#8 posted 02-28-2012 04:45 PM
I’ll bet you are right, Don Johnson.
-- Dan V. in Indy
doninvegas
#9 posted 02-28-2012 11:17 PM
tootles,
My problem is the hammering. My hand eyes coordination isn’t has good as it used to be. So when I miss or get close to having the nail all the home I mess up the brass hasp. I’m going to try the drill press method the next time.
Tootles
#10 posted 02-29-2012 07:53 AM
Thanks for the reply Don. The drill press idea is certainly a good one.
Of course, that same brass rod could be used with a hammer in much the same way as you’d use a nail punch on a standard nail. The idea is simply to get some distance between the hammer and the brass hasp so that missing is less of an issue.
