Spraying latex paint
Forum topic by bleecker posted 02-27-2012 10:25 PM 1746 views 0 times favorited 5 replies Add to Favorites Watch
View bleecker's profile
bleecker
3 posts in 2516 days
02-27-2012 10:25 PM
Hi,
I have an Earlex 5000 hvlp spray unit. I want to spray latex paint. I have two needles: 1.5mm and a 2.0mm. I am looking for a recipe to thin the latex paint.
Thanks.
5 replies so far
View Chipy's profile
Chipy
374 posts in 2828 days
#1 posted 02-27-2012 10:39 PM
I haven’t sprayed any paint with my Earlex but I think you cut the paint with water until you get the right viscosity using the viscosity cup that came with your unit.I know there is a minimum viscosity that you have to achieve before you can spray anything out of this gun.
View joey bealis's profile
joey bealis
177 posts in 2742 days
#2 posted 02-27-2012 10:52 PM
when spraying latex I usually end up with around 15 to 20% water. I try to get mine on the last coat to just barely be able to spray it. The color and finish look better. Too much water will dull it if it is a gloss or eggshell.
-- http://reclaimedbuilding.blogspot.com/
117416 posts in 3812 days
#3 posted 02-27-2012 10:56 PM
Take look here
http://www.earlex.com/hv5000-accessories.php
View Sawkerf's profile
Sawkerf
1730 posts in 3303 days
#4 posted 02-27-2012 11:37 PM
I can’t recall the name right now, but there’s a product available to thin latex paint without actually diluting it like water will do. I’ve had good luck with it.
bleecker
#5 posted 03-01-2012 03:44 PM
Sawkerf—
Any luck remebering the product for thinning? I did try about 20% denatured alcohol and 10% Floetrol. (I saw a recipe that calls for another 10% of household amonia to stablize the thinned latex paint.) It worked nicely on the primer, but it seems to have robbed the satin top coat of its sheen. I may try a semigloss next or topcoat everything with an oil based satin poly. The nice thing about denatured alochol, Floetrol, and amonia is that they are cheap. Paint, unfortuantely is not cheap.
Thaks.
