window trim question
Forum topic by RinnyTin posted 02-27-2012 07:24 PM 1052 views 0 times favorited 5 replies Add to Favorites Watch
View RinnyTin's profile
RinnyTin
39 posts in 2797 days
02-27-2012 07:24 PM
Topic tags/keywords: window trim sill stool
Hi all. I’ve cut stools and case for windows before, but have just had 2 windows installed in our 3rd floor renovation that are a bit different than any I’ve worked on. Can anyone advise on where the stool sits and how it fastens to the frame? Thanks in advance.
5 replies so far
RinnyTin
#1 posted 02-27-2012 07:26 PM
From FS
From FS
View chrisstef's profile
chrisstef
17800 posts in 3245 days
#2 posted 02-27-2012 07:33 PM
Id attach a block to the existing lower framing and run the stool off of that.
RinnyTin
#3 posted 02-27-2012 07:51 PM
@ chrisstef: thanks for the reply, so the top of the stool is flush with the 1.5” strip like this?
From FS
Not sure how a block underneath would work, there’s only a 1/2 inch depth there if I want to run an apron.
chrisstef
#4 posted 02-27-2012 08:30 PM
im fairly certain it sits flush like you have drawn. i do see your problem with the apron or trim though. Maybe you could attach it directly to the apron and then put them in together nailing on through the apron? Might leave it awfully weak though if someone was to lean on it.
RinnyTin
#5 posted 02-27-2012 08:53 PM
maybe I do a 1/2 block up to the sheetrock and then a 5/4” apron, would look a bit bulky but probably make it solid if the stool is sitting on 1 and 3/4 inches?
