Support arm for Dewalt 788 Scroll Saw
Forum topic by ldl posted 02-26-2012 01:54 PM 5565 views 1 time favorited 6 replies Add to Favorites Watch
View ldl's profile
ldl
1135 posts in 2363 days
02-26-2012 01:54 PM
Topic tags/keywords: scroll saw modifications tip
After posting this project on a prop for my Dewalt SS arm (http://lumberjocks.com/projects/60970) I was informed by Godofbiscuits of a diff support for the arm. On looking at it and also seeing it on Steve Goods link I decided to build my own. I used a 10g x 1 1/2 x approx 18” piece of sheet metal and drilled and slotted it for the support. I believe a 1” wide piece of metal would have been sufficient but the sheet metal was given to me so I used it like it was. I like free. The only diff is Steve used the top bolt on front of arm and I mistakenly used the bottom but it makes no diff that I can tell. For the slot I drilled 4 holes close together and took my dremel tool and ground out the middle. The spring I bought had two in a pack and I found was a little week so I had to use both of them. I will go back later and get a stronger spring so as to use only one. Cost to me was $3 for the springs and $4 for the longer bolts, washers and lock nuts.
I used the saw this weekend and the support made all the difference in the world in the operation of the saw. I no longer had to put the prop I made under the arm each time I changed the blade to a new hole. I just raised it up and it stayed. I then changed the blade and reached up and easily one brought it back down.
I agree with Godofbiscuits that it should be standard equip on the Dewalt saw. If you have a Dewalt 788 or similar saw this is a most needed modification IMHO.
This is the link to Steve Goods video. You have to go to bottom of the site to see the video. http://scrollsawworkshop.blogspot.com/2010/10/jim-dandy-products-easy-lift-and.html
-- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - -
View ldl's profile
ldl
#1 posted 02-27-2012 03:00 PM
Did I say something wrong with this post? I am rather new here so if I did do something wrong here please let me know.
View MrsN's profile
MrsN
986 posts in 3524 days
#2 posted 02-27-2012 07:44 PM
you didn’t say anything wrong, just not too many of us scrollers on the site sometimes.
Your arm looks great! I don’t have a dewalt, but I like what you have done with it.
View ldl's profile
ldl
#3 posted 02-28-2012 12:44 AM
It had me wondering for a while that maybe I had broken some written or unwritten rule when no one responded after 158 views. Glad it ain’t so. Feel better now.
Thanks for the comment.
View NormG's profile
NormG
6111 posts in 3002 days
#4 posted 02-28-2012 01:04 AM
Glad to see you found a solution. Wlcome
-- Norman - I never never make a mistake, I just change the design.
View redryder's profile
redryder
2393 posts in 3100 days
#5 posted 06-10-2012 06:18 AM
Steve Good does another excellent video on how to install this simple product….............
-- mike...............
View ldl's profile
ldl
#6 posted 07-01-2012 03:13 AM
I looked at the Bigfoot drop down arm but didn’t like the fact that you have to swing it down and up each time. With the lever such as I have you only have to push up the arm and it stays then pull it down again.
I saw where Bigfoot has designed another arm similar to what I have and can be seen on Steve’s place. I still like my arm better though. One reason is it was free but the other reason is for me it werks better I think.
