| Forum topic by getlostinwood | posted 455 days ago | 632 views | 0 times favorited | 8 replies | ![]() |
455 days ago |
I’m in the process of building my youngest daughter a maple and walnut dresser. Maple out of the fire wood pile, so far so good. Rough walnut truly beautiful but has grain switching back and forth on every freaking board. I send it through one way and it gets halfway through and then tear out, send through the other end first, same thing different end. Small stuff I could stand to do some extra work with the scraper but I literally set the planer to cut a 64th and ended up with some 8th inch deep tearout. Blades have about 10 hours of run on them, I hone them lightly before each use and they are still sharp enough that I get smooth cutting halfway through that looks great but as soon as the grain swithches on me the tear out will make you cringe. I’m thinking I have found the reason for a thickness sander. Any advise will be greatly appreciated, I’m as frustrated as a spotter bull in spring…............... -- The basis for optimism is shear terror |
