Serious Comparison: Daly's ProFin vs. Minwax Wipe On Poly
Forum topic by Lee Barker posted 449 days ago 1227 views 0 times favorited 4 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
1884 posts in 1017 days
449 days ago
Topic tags/keywords: wipe on poly urethane varnish
There’s an abundance of opinions about finishes on LJ, many of them sounding like this: “I’ve always used SchmidFarns Sleek Elite #2.” If there’s no comparison, there’s not much weight there.
I had the opportunity this week to do this comparo: Two bass bodies, identical woods (cherry/alder), prepped exactly the same, stained with the same product and shade, finished in the same room, same lighting over each. There are a lot of constants there, like humidiity, temperature (it stays at 70oF there with the lights on), same application techniques, same filter materials, same applicators (4” square of cotton).
The bass bodies are on rotisseries so there are no real vertical applications.
Both products are labeled “semi gloss.” Minwax recommends recoat in 2-3 hours; ProFin in 4 – 8.
Here are my observations:
Minwax:
Always ready to recoat in three hours
Easy to get a thin, even coat
Lower sheen
ProFin:
Wanted to go on thicker; if I tried to thin the application, it would get streaky.
Really cuts back into existing finish quickly, almost like a lacquer.
Sometimes took all of 8 hours to dry to recoat
Higher sheen
Apparently more build
I am at 6 coats of each. I’ll repost in a few days.
Rough costs: Minwax, $24/qt. (in pints); ProFin, $17/qt.
Have you ever done a head to – head like this with finishing products? Let us hear about it!
Kindly,
View Vasko's profile
Vasko
271 posts in 853 days
#1 posted 449 days ago
I hope we’ll hear more head-to-head comparisons like this, thanks for your observations!
-- - Cindy, texture freak -
View Arlin Eastman's profile
Arlin Eastman
1312 posts in 727 days
#2 posted 449 days ago
A friend of mine that is all he uses for his wood turnings is Minwax.
Arlin
-- It is always the right time, to do the right thing. Lovinghandsmemoryboxs.com
View Dez's profile
Dez
1097 posts in 2243 days
#3 posted 447 days ago
Thanks Lee, I always appreciate real world performance results!
I have tried both but years apart and on different projects (ProFin on outdoor stuff!)
-- Folly ever comes cloaked in opportunity!
Lee Barker
#4 posted 447 days ago
The two projects sat over the weekend and are amply dry to the touch. The MinWax one is very near to ready to go. It will sit for a week before rubout.
The Daly one is a disappointment at this juncture; the finish has streaks in it, gloss vs. less gloss. This can be repaired, and I also think it could have been prevented had I thinned the product just a bit. I am confident that I stirred and strained it before each application.
I am glad I didn’t know that, because the accuracy of this comparo is dependent on constants, including using the product right out of the can. (That said, this can had been opened once three months ago. I decided that shouldn’t be enough to affect the test. Now you know. Maybe it did.)
To repair the Daly I’ll let it sit a week likewise and then wet sand it and recoat it with slightly thinned ProFin. That might complete it.
