Router table parts
Forum topic by RussellAP posted 451 days ago 653 views 0 times favorited 2 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 454 days
451 days ago
I’m planning on building a router table. I have a PC router and table, but I’m not too happy with the fence system and it’s either too high or too low depending on if I put it on my bench.
What I need is to know if I can get my Porter Cable router an accessory that is basically a square mount. I’d like it to be made of steel, and be anywhere from 6 to 8 inches square so it will sit in the cut-out of the table, which will likely be a 3×4 kitchen counter-top.
Or if you have proven alternative idea’s I’d be very interested in hearing about them. I want this piece in hand before I design the table.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
2 replies so far
View stevenmadden's profile
stevenmadden
173 posts in 1257 days
#1 posted 451 days ago
Russell Pisciotta: Not sure if this is what you are asking for, but I built my router table around a torsion box core. You can check it out here:
http://lumberjocks.com/projects/60978
I also made a fence for it. If you are interested, I can send pictures or details. If not, good luck with your build. I look forward to seeing your final product.
Steven
RussellAP
#2 posted 451 days ago
I just found the woodpecker site and am trying to find out if it will fit a PC 892
