craftsman lathe #31.21717
Forum topic by EKR posted 02-24-2012 08:38 AM 870 views 0 times favorited 1 reply Add to Favorites Watch
View EKR's profile
EKR
1 post in 2278 days
02-24-2012 08:38 AM
Topic tags/keywords: lathe
Need to find the ” value” of a resistor/capasitor on the circuit board. Can’t find a diagram on line.
1 reply so far
View nwbusa's profile
nwbusa
1021 posts in 2280 days
#1 posted 02-24-2012 09:04 AM
If you can isolate the component, you can check the resistance of the resistor with an ohm meter. If it’s an older through hole component and has the color bands on it, then a quick Google search might also provide the value. For a cap, unless it’s marked on the body of the component, you’d need a z-meter, if memory serves. It’s been 20 years since my electronic theory classes, though :) good luck
-- John, BC, Canada
