Using a Thickness Planer for Jointing
Forum topic by andy6601 posted 02-23-2012 07:35 PM 15115 views 0 times favorited 5 replies Add to Favorites Watch
View andy6601's profile
andy6601
91 posts in 2583 days
02-23-2012 07:35 PM
Hello everyone I have a question, can I use my thickness planner for jointing or should I use a jointer for joining. I have a 12” Grizzly thickness planner and it is great, but i have a whimpy 4” craftsman jointer that is, well, whimpy. So can, or should I find a 6” jointer and use that, or just use my thickness planer to join the borads. What I do is I get wood that is rough and knock saw marks off, really I only care about surfacing the faces of the boards, I have a jointer hand plane that I can use to shoot the ends of the boards for making panels say for a chest of drawers, etc. So my next question is would I even need a jointer and really what are they primarly used for? I know this is a 5th grade question but most books and magizines I read never cover how to take a board from the rough and get it to the point to which you start to use if for projects. Then say if I was to get a 6” jointer I don’t want to have to cut all my boards down to 6” or less because then I end up with a bunch of boards that need to be glued together if I am making a large panel. Any thoughts on this would be great. Thanks.
5 replies so far
View Gene Howe's profile
Gene Howe
10819 posts in 3543 days
#1 posted 02-23-2012 07:53 PM
On occasion, I have ganged drawer sides/backs and fronts and clamped them together to run through the planer.
More to insure perfect equal widths than for jointing.
View knotscott's profile
knotscott
8120 posts in 3490 days
#2 posted 02-23-2012 08:02 PM
A planer and a jointer are different tools and really different purposes. A jointer flattens a face and squares and adjacent edge. A planer smooths and reduces the thickness without regard to true flatness.
A planer doesn’t have a true reference point for flattening or squaring boards, which a jointer does have. If you use a planer sled that’ll act as a flat reference point, you can flatten the face of a board. Without the sled, the planer is mainly just duplicating the natural shape and undulations of the board’s surface….twisted board, twisted board out.
View SASmith               's profile
SASmith
1850 posts in 3102 days
#3 posted 02-23-2012 08:17 PM
Here is another post on using your planer to face joint boards.
-- Scott Smith, Southern Illinois
View Bill White's profile
Bill White
5047 posts in 4075 days
#4 posted 02-23-2012 08:30 PM
I use a slave board like shown with pretty good results. Having said that, I don’t use a lot of solid woods for panels in cabinetry.
I keep a bunch of wedges and dbl. sided tape at hand.
Bill
-- bill@magraphics.us
View Lumber2Sawdust's profile
Lumber2Sawdust
139 posts in 2980 days
#5 posted 02-24-2012 04:27 AM
The way I read your question, I believe I’m doing the same thing you are talking about: I use a jack and jointer plane to get a flat face. At this point, I run it through the planer – flat face down. The jointed face is the reference that the planer needs. I then use the jointer plane to create a straight edge, checking it with a square as I go. I use a table saw to rip the opposite edge parallel to the one I jointed.
I could make space for a corded jointer in my shop, if I really needed it, but I kind of prefer to have the extra space. It doesn’t take that long to flatten the boards by hand, once you get the hang if it and I prefer the quiet rhythm of the planes to a jointer.
