Am I just being lazy?
Forum topic by richgreer posted 453 days ago 1322 views 0 times favorited 40 replies Add to Favorites Watch
View richgreer's profile
richgreer
4474 posts in 1243 days
453 days ago
Whenever I am cranking my TS to tilt my blade from 90 degrees to 45 degrees I remember the days when we used to raise and lower the windows in our cars and trucks by cranking on a handle. I have not even seen a window crank in many years. Ever car or truck I drive or ride in has power windows.
So I ask myself – - Why can’t we get a power crank on our TS tilt mechanism? I wonder the same thing when I am raising or lowering the table on my drill press. A third (perhaps less important) application could be applying tension on our bandsaws.
I know it would cost a little more but I think I would be willing to pay it.
I know that a power router lift is available from MLCS. Frankly, I don’t see that as a big need. I would much rather have a power system for the TS tilt mechanism and my drill press table lift mechanism.
Are any tool manufacturers reading this?
40 replies so far
View poopiekat's profile
poopiekat
2828 posts in 1902 days
#1 posted 453 days ago
I’d be interested too, Rich! But only if there was an accompanying digital readout, indicating exact tilt and blade height. Same with the fence, I’d like to see a fence system where the fence rides on acme screws in front and in back of the table, again with a digital readout indicating exact distance to the blade.
View whitedog's profile
whitedog
649 posts in 1625 days
#2 posted 453 days ago
Maybe we could ask the government to include than with the sawstop feature … :-) .
Sounds good to me my up and down crank is easy , but the angle crank takes forever.
-- Paul , Calfornia
View zindel's profile
zindel
229 posts in 818 days
#3 posted 453 days ago
I agree with everything except throw in a manual micro adjuster, motors are not all that easy to stop right at the spot you want it to be at.
-- If you can't fix it with a hammer, You've got an electrical problem.
View Viktor's profile
Viktor
467 posts in 1587 days
#4 posted 453 days ago
The reason cars have power windows is because you often need to operate them while driving with minimum distraction. When you cranking your saw there is less need for it, you have your full attention and can’t do anything else at the moment anyway.
Just having power crank on saw is not enough. You need feedback circuitry to be able to stop it at precise angle or height (try to set your power window at exactly 32 mm). This complicates the mechanism significantly and also requires precise step motors. Hence the option is only available on high end panel saws.
View Danpaddles's profile
Danpaddles
389 posts in 480 days
#5 posted 453 days ago
Didn’t Sears do something like a power tilt for a band saw, some time back?
I’d love a power lift for my DP, I just leave the table a little low, then block up my work, often as not.
-- Dan V. in Indy
View ETwoodworks's profile
ETwoodworks
92 posts in 861 days
#6 posted 453 days ago
Sounds like just another switch to go bad and leave ya stranded to me.
-- Building quality in a throw away world.
View SnowyRiver's profile
SnowyRiver
45700 posts in 1648 days
#7 posted 453 days ago
This would be great Rich. Just think a power fence would be nice too…LOL. Heck, I have CB radio on my table saw with a coon tail on the antenna :-)
-- Wayne - Plymouth MN
View HorizontalMike's profile
HorizontalMike
4930 posts in 1082 days
#8 posted 453 days ago
And I would like to have my own personal woodworker too. Then I wouldn’t have to… er… uh… oh wait a minute… that would then mean that… oh never mind… oops…
TopamaxSurvivor
13192 posts in 1844 days
#9 posted 453 days ago
It won’t be long until nobody has any muscle tonne left ;-))
View Lee Barker's profile
Lee Barker
1887 posts in 1018 days
#10 posted 453 days ago
I like power tools, but I don’t want to give up using my hands in tandem with them. The idea of a push button table saw with power feed is the province of a millwork place, not one where listening to the cut and adjusting the rate of feed when there’s a knot in the road is part of the human contribution to the end product.
I further enjoy exercising the intuitive side by guessing halfway points, estimating screw layout, and grabbing a handful of screws or dowels for a process and find that I’m within one or two of exact.
These are things that remind me I’m alive and at the right place at the right time, much as the moment my 4 year old grandson got in my 1992 truck for the first time, pointed at the window crank, and said, “What’s that, grampa?”
Kindly,
View CalgaryGeoff's profile
CalgaryGeoff
496 posts in 650 days
#11 posted 453 days ago
Day dreams of wood workers. More hp, larger shop, more power, better light, bigger capacity, personal wood working apprentice(like at tatoo joints), more storage, more wood. And of course more time.
I like the idea of power lifts on table saws. CNC stepper motors can position to within thousands of inch.
This might be a project for SPalm, he’s built a CNC machine. A motor on a table saw he should be able to figure out in his sleep
-- If you believe you can or can not do a thing, you are correct.
View BUBBATAY's profile
BUBBATAY
25 posts in 482 days
#12 posted 453 days ago
Reminds me of an old sager and evans song
View DS's profile
DS
1820 posts in 588 days
#13 posted 452 days ago
Rich, there are retro-fit cnc drives for overhead mills that are bolt on and could easily be adapted to the TS.
It might be cool to dial in the blade height and tilt angle via touch screen. All I’d need then is a start button to actually perform the cuts for me…. uh, wait… that’s what a CNC router does. Check that. (I knew there was a reason I keep renting time on that big machine.)
poopiekat
#14 posted 452 days ago
My crappy Hewlett/Packard printer scanner has precision motors that stop exactly whever it is told to , and it was given to me by the dealer when I bought my new computer. That electo-mechanical stuff cannot be expensive. And what the hey, power tools is power tools, if you’re going to use them!
View crank49's profile
crank49
2284 posts in 1139 days
#15 posted 452 days ago
Poppie, they sell those printers for $29 and the replacement ink cartridges for $59. You think maybe the printer is the loss leader in this case? (marketing lingo for bait and switch)
In any case, the little stepper motors that drive the print head are certainly accurate, but they are not powerful enough to raise DP tables or TS arbors.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
showing 1 through 15 of 40 replies
