Fixing A cracked Glue Joint
Forum topic by MNJackofAllTrades posted 02-23-2012 04:21 PM 925 views 0 times favorited 4 replies Add to Favorites Watch
View MNJackofAllTrades's profile
13 posts in 2238 days
02-23-2012 04:21 PM
Topic tags/keywords: question oak clamp joining finishing refurbishing
I need some help. I have a couple of drawer fronts that I glued up from solid oak. When I brought them in from the shop they dried out a bit and one side of the glue joint opened up. The glue must be a little old. Time to throw that bottle out. Anyhow the opposite side is rock solid, but the crack is about 1/32 to 1/16 wide. The question is, what is the best method of getting glue in there so I can reclamp it an close up the gap? The drawer fronts are already stained, but not yet finished.
View Bill White's profile
Bill White
4879 posts in 3895 days
#1 posted 02-23-2012 04:32 PM
I keep an artist’s pallette knife in the shop for just such uses. That, a small art brush, a toothpick, or just forcing some glue in with pressure from the nozzle would work. Wipe off the excess and clamp. There ya go.
View tenontim's profile
2131 posts in 3679 days
#2 posted 02-23-2012 05:47 PM
You only get one shot with glue. It won’t stick to itself. You’ll have to get all of the old glue off, before you’ll be able to get a reliable glue joint. Acetone will dissolve most white and yellow glues.
404 - Not Found
2544 posts in 2904 days
#3 posted 02-23-2012 07:05 PM
I don’t how much good it will do to get glue between the cracks and reclamp it…
If you’re going to do it anyway, put a liberal amount of glue on one side and suck the glue through the crack with a workshop vac. This really does work well. Clean up, cramp, clean up again.
I saw a Gorilla Glue video on YouTube of a GG technician repairing an old chair. Gorilla Glue “LOVES” old glue and finishes… (well, according to the video it does), so that might be a more suitable adhesive altogether.
In either case it’s possible you may have to sand down and restain, you might be better off remaking them altogether.
View NiteWalker's profile
2736 posts in 2511 days
#4 posted 02-24-2012 05:00 AM
I’d skip yellow glue and try some 5 minute epoxy.
