Floating Joint for Table Top
Forum topic by Matt posted 02-23-2012 01:55 PM 1339 views 0 times favorited 2 replies Add to Favorites Watch
View Matt's profile
Matt
5 posts in 2193 days
02-23-2012 01:55 PM
Topic tags/keywords: joining
Does anyone have suggestions for putting together large table tops that will avoid such issues as warping and cracking? My work is somewhat rustic, and I use large reclaimed planks 2×6 to 2×12 that don’t need to be joined seamlessly.
I am thinking I should use breadboards or battens to hold them together, or even a loose spline between grooves.
I am looking for other suggestions if anyone has something that has worked well.
2 replies so far
View RGtools's profile
RGtools
3372 posts in 2560 days
#1 posted 02-23-2012 02:09 PM
If gaps are not an issue, breadboard ends might be the way to go. You make the mortises a bit wide and drawbore the planks towards the center to allow for some seasonal movement.
Cut nails work too since your are going for the rusting thing (nails flex….glue not so much)
But there are a lot of ways to get this done.
-- Make furniture that lasts as long as the tree - Ryan
View bondogaposis's profile
bondogaposis
4601 posts in 2256 days
#2 posted 02-23-2012 02:10 PM
The simple approach would be to use battens with slotted holes. A lot depends on what type of leg construction you are planning, are we talking picnic table here?
-- Bondo Gaposis
