Wipe on Poly
Forum topic by Kayvon posted 482 days ago 1132 views 0 times favorited 8 replies Add to Favorites Watch
View Kayvon's profile
Kayvon
51 posts in 503 days
482 days ago
Topic tags/keywords: question finishing
I have noticed that several of the LJs use wipe on poly as a finish. Does anyone know brands and places that sell the good stuff.
Thanks.
-- Kayvon
8 replies so far
View grumpy749's profile
grumpy749
115 posts in 575 days
#1 posted 482 days ago
I use minwax and am very pleased with this product I Prefer satin over gloss. Have a look at my last project, a live edge maple coffee table finnished with hand rubbed poly and 400 grit wet and dry paper. I buy it at Home Depot.
-- Denis in Grande Prairie. Yesterday is history, tomorrow is a mistery, but today is a gift. That is why it is called the present.....Pink !
View Clint Searl's profile
Clint Searl
884 posts in 559 days
#2 posted 482 days ago
Don’t buy it…make it. Get a quart of Varathane oil poly in the sheen of your preference and thin as much as needed for a project 50:50 with naphta. Wipe it on and off as many times over as many days as you want.
-- Clint Searl.............We deserve what we tolerate
View interpim's profile
interpim
1117 posts in 1656 days
#3 posted 482 days ago
I use the minwax wipe-on poly for a lot of my turnings…
This one I used gloss
Click for details
-- San Diego, CA
View supercubber's profile
supercubber
17 posts in 482 days
#4 posted 482 days ago
General Finishes makes a good wipe-on poly and is available at Woodcraft.
View TexasJim's profile
TexasJim
86 posts in 1434 days
#5 posted 482 days ago
Some folks really despise poly. I have used it and like it. I am in the “make your own” camp. I dilute 50/50 with mineral spirits and wipe with a rag from an old t-shirt. You will need a lot more coats than if you used full strength. For furniture and boxes I put on about 4 coats of wiping varnish.
-- If the world was a logical place, men would be the ones who ride horses sidesaddle.
View richgreer's profile
richgreer
4472 posts in 1272 days
#6 posted 482 days ago
I experiment with other finishes, but my standard approach is MinWax wipe-on poly. IMO, the gloss is too glossy and the satin is too dull. Therefore, I usually mix them 50/50 and that works out fine.
Be advised – once you mix them you have a shelf life of about a week. I don’t know why, nor do I worry about it. I just mix up enough for the current need and proceed.
View Bearpie's profile
Bearpie
2475 posts in 1215 days
#7 posted 482 days ago
I love the wipe on poly cause it is so darn easy to apply to my turnings just before I take it off the lathe. I run my machine at low rpms (about 70) and apply the poly with a piece of old T-shirt and keep applying till it absorbs no more then go over it again to remove any excess poly. I usually leave the machine running for about an hour till it is mostly dry to prevent runs! I prefer high gloss for my turnings. I keep applying additional coats till I’m satisfied with the “look”.
-- Erwin, Jacksonville, FL
View KenBee's profile
KenBee
108 posts in 833 days
#8 posted 480 days ago
I use Minwax Clear Satin wipe on over shellac and it turns out very nice. I use one coat of BLO, 3 coats of Shellac and 2 coats of wipe on Poly using a 3M finishing pad lightly between each coat of Shellac and Poly. That combination makes the colors and grain really pop, especially Red Oak and Walnut.
-- If it won't fit get a BIGGER hammer.
