Routing freehand or in a router table....
Forum topic by Chris posted 81 days ago 151 views 0 times favorited 9 replies Add to Favorites
View Chris 's profile
Chris
1121 posts in 426 days
81 days ago
Topic tags/keywords: router
I plan building a desktop that is about 1” thick and am considering using a 1” or 3/4”??? round over bit for the edge treatment (this would be done from the bottom side; leaving the top edge flat).
Would you consider this size bit excessively dangerous to use free hand?
-- Chris
View GaryK's profile
GaryK
8392 posts in 423 days
81 days ago
You can’t put a 1” rad on a 1” edge unless you added something temporarly make it thicker.
3/4” would be fine by hand, just be careful near the corners.
Chris
81 days ago
Why is that Gary…. Tear out?
-- Chris
View EdC's profile
EdC
415 posts in 275 days
81 days ago
Garys right about the corners I would do the ends (end grain) first thats where you’ll have to most tear out. That way you stand agood chance of cleaning it up when you cut the long grain. Take your time!
-- Ed Collinge- Edmonds, WA.
View FlWoodRat's profile
FlWoodRat
235 posts in 344 days
81 days ago
Make sure you do it in multiple passes, taking off a little at a time. BTW, you cant use a 1” round over with a bearing guide on 1” stock because the bearing will be below the edge. I believe that’s why he suggested attaching at stip to the stock before routing.
-- Even the best of men relish a little spice every now and then... HG Somers, circa 1905
Chris
81 days ago
Ok… I got that…. Now back to my original question.
Do you think it’s safe to use a 3/4” to 1” bit freehand in a single speed router?
I don’t know of any other way to get this done…
-- Chris
View bayspt's profile
bayspt
56 posts in 139 days
81 days ago
A 1” roundover bit is about 2 1/2 ” diameter. Not sure on the rule but that should be getting close the the diameter that one would need to slow down. However I think you could do it with a fixed speed router freehand if you where carefull especially on the end grain. I sure wouldn’t try to climb cut with it though, and I would take very narrow passes. An offset router base might make it more safe, and can be made for free if you got the scraps. Just me .02
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
View shiney5757's profile
shiney5757
71 posts in 206 days
81 days ago
slower motor speed and shallow passes is prefered,
in any case be carefull.
my motto is if not sure try something different.
-- I cut it twice & it was still too short
1778 posts in 456 days
81 days ago
Against the grain, with the grain, against the grain, with the grain.
Small passes to make sure tha the tearout is minimal.
bob
View trifern's profile
trifern
3074 posts in 202 days
80 days ago
I agree. Multple passes cutting the end grain first.
-- Depend on the rabbit's foot if you will, but remember it didn't work for the rabbit.
Bookmark And Share This Page
