carving wood bowls without a lathe
Forum topic by jennifer13 posted 02-21-2012 09:29 PM 14935 views 0 times favorited 7 replies Add to Favorites Watch
View jennifer13's profile
jennifer13
2 posts in 2194 days
02-21-2012 09:29 PM
Topic tags/keywords: question carving shaping rustic modern chisel carving tool
Anyone have any info on how to carve a wood bowl or tray without using a lathe. I plan on using a dremel tool and wood carving chisels. My goal is NOT to make a perfect round bowl.. I don’t mind an organic shape with imperfections, so long as it is still artistically appealing. Tips, advice, love.. all appreciated! Thanks : )
7 replies so far
View Elizabeth's profile
Elizabeth
817 posts in 3049 days
#1 posted 02-21-2012 09:35 PM
For the inside, I might try hogging out much of the central material with forstner drill bits on a drill press, and then you could clean up the edges using the dremel and chisels…
For the outside, you can get it circular on a bandsaw with a jig, and maybe if you tilt the table you can approach the bowl shape that you want? I haven’t tried this myself.
View hairy's profile
hairy
2607 posts in 3438 days
#2 posted 02-21-2012 09:40 PM
View Loren's profile
9958 posts in 3554 days
#3 posted 02-21-2012 10:44 PM
bowl adze, lancelot carver, even the table saw.
View bent's profile
bent
311 posts in 3575 days
#4 posted 02-21-2012 11:14 PM
check out the CMT bowl/tray kit that rockler sells. it’s a essentially a specialized router bit and template set.
jennifer13
#5 posted 02-21-2012 11:33 PM
ahhh a bowl adze… good to know that exists… Thanks everyone for your input : )
View MrWizard's profile
MrWizard
145 posts in 2710 days
#6 posted 02-22-2012 12:00 AM
Very cool tools out there just be safe during your creation.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3432 days
#7 posted 02-22-2012 02:17 AM
A Shinto rasp will help you greatly.
