need to get glue joint apart
Forum topic by woodnut posted 129 days ago 182 views 0 times favorited 8 replies Add to Favorites
View woodnut's profile
woodnut
110 posts in 534 days
129 days ago
hello guys and gals I could use a little help and I know that I’ve come to the right place. So the problem is I have a glue joint ( mortice and tenion ) that I need to get apart with out damaging the wood , is their any hope for me. What can I do to weaken the glue so I can seperate the pieces?
-- F.Little
teenagewoodworker
2026 posts in 250 days
129 days ago
if its freshly glued i don’t think that you will have much luck with that. the only thing i could think of would be to cut off the tenon piece and reshape the mortise. and make a new tenon piece. other than that i don’t think that there is that much that you can do.
View Roper's profile
Roper
369 posts in 195 days
129 days ago
hello woodnut, yellow glue has a life of like 25 years so if you just glued the joint the best bet is to cut the tenon like tww said. if it is oid some rocking back and forth and some moisture should do the trick.
-- Roper - master of sawdust-
View GaryK's profile
GaryK
8482 posts in 470 days
129 days ago
If it’s yellow glue, you can steam it.
View BrianM's profile
BrianM
114 posts in 234 days
128 days ago
Heat gun will work.
-- There is no such thing as scrap wood!, http://www.saltrivergallery.com
View motthunter's profile
motthunter
1216 posts in 281 days
128 days ago
HEAT.. STEAM… or you can drop it in the center of a nuclear reactor and pray… (if oyu dont mind it glowing in the dark)
New glues are too good… They are rarely forgiving and designed to hold forever.
-- making sawdust....
View Chiefk's profile
Chiefk
40 posts in 253 days
128 days ago
Woodnut, I have had some success using white vinegar in combination with a heat gun. I once glued a cabinet face frame and need to take it apart again. I was about to start over building a new face frame, when my wife said she could open the joint. She brushed the vinegar along the joint line allowing the vinegar to seep into the joint. After working with it several minutes, she was able to open the joint. It was a fairly easy process. To my utter surprise. The vinegar didn’t seem to have any adverse effect on the wood. Good Luck, pkennedy
-- P Kennedy Crossville, TN
View EdC's profile
EdC
420 posts in 322 days
128 days ago
White vinegar is what I would try as well. I use vinegar to clean dried glue out of tips for my applicator.
-- Ed Collinge- Edmonds, WA.
woodnut
128 days ago
just thought I’d let you kinow that the heat gun did work thanks for the advice guys
-- F.Little
Bookmark And Share This Page
