Ridgid R4512 riving knife lever hard to move
Forum topic by Matt Przybylski posted 460 days ago 1107 views 0 times favorited 7 replies Add to Favorites Watch
View Matt Przybylski's profile
Matt Przybylski
291 posts in 550 days
460 days ago
Topic tags/keywords: ridgid r4512 riving knife
Hello fellow LJs,
A few months back I purchased the Ridgid R4512 and love the saw. Initially the lever you lift up and down was easy to move around but now I have to either hit it down with a mallet or use pliers to move it up/down. I don’t want to be hitting it with anything considering how close it is to my blade so I tried to clean it off as well as I could and put some wd40 on it. That didn’t seem to help much if at all. Have other owners of this saw had issues with this as well? What can I do to make it easier to move in and out of position when changing blades?
-- Matt, Illinois, http://www.reintroducing.com
7 replies so far
View peterbb's profile
peterbb
31 posts in 460 days
#1 posted 460 days ago
On my R4510, I had to remove the riving knife mount (two large allen screws to the right of the knife) – then I could see and adjust the clamp tightness, then rte-align the knife with the blade. I think I decided later that I could tip the saw up on end, and access the adjustment from under the saw (the 4510 is on a cart).
-- Peter
View terry603's profile
terry603
318 posts in 1086 days
#2 posted 459 days ago
i have the 4510 ,and mine is real stiff also i use an open end wrench to hook onto it in order to get it to move. can’t remember if it is 7/16 or 3/8 inch
-- may not always be right,but,never in doubt.
Matt Przybylski
#3 posted 459 days ago
Thanks guys, I suppose knowing I’m not the only one with the issue makes me feel a bit better. I suppose I’m going to just keep using pliers to grab it and pull up/down on it. I can always hit the pliers with the mallet I suppose. Peter, I’m not sure I feel comfortable taking the whole assembly apart.
View jeff's profile
jeff
427 posts in 1637 days
#4 posted 459 days ago
i have the 4512.i think your talking about the orange lever to loosen the riving knife if i read this correctly.mine has become harder to move but i can still loosen it with my hands but now i prefer a small piece of wood.i just wedge it under the lever and lift,and then to tighten i tap it down with a rubber mallet because i don’t want to rack my knuckles.i also use my air compressor frequently to clean out the inside.remember the 4512 has a warranty and i wouldn’t hesitate to call the Rigid people.wish i could help more.
-- Jeff,Tucson,Az.
Matt Przybylski
#5 posted 459 days ago
@Jeff: that’s exactly what I’m talking about. I also use my compressor to clean it out quite often. I don’t tighten the back six bolts down so I can easily open them and clean out the insides about bi-weekly. You’re right, I should just call Ridgid and ask them about it, good call.
View RyRed's profile
RyRed
1 post in 453 days
#6 posted 453 days ago
I have the same problem with my R4512 which I purchased in December. I just use leverage to compensate. If you hear anything from Ridgid, please keep us posted!
View evotron's profile
evotron
1 post in 441 days
#7 posted 441 days ago
I have a solution for everyone—it’s really easy, or at least it is for the r4510. The riving knife lever pivots on a bolt that passes through the full mechanism with a nylon locknut on the other end. All you need to do is loosen that nut a little bit so the lever clamps the knife firmly but isn’t impossible to lock down. To get to it, lower the blade completely and (for the r4510) put the saw in the stand’s upright mode. Remove the plastic shroud that covers the blade and channels the sawdust to the exhaust port (this is so you can access the lever to fine-tune the nut). You’ll see the lever on the top side of the blade housing and the bolt going through it passing downward. Look underneath the blade housing and you’ll see the locknut on the other side. Adjust the nut as needed. The locknut isn’t the tightest fit, and I was able to tighten/loosen it by hand with a 12mm socket—which makes it easy to adjust, but probably also explains why it so readily goes out of whack, and it’ll probably always require occasional adjustment.
