| Forum topic by wseand | posted 457 days ago | 951 views | 0 times favorited | 8 replies | ![]() |
457 days ago |
Topic tags/keywords: question oak finishing zinsser seal coat minwax polyurethane I am finishing a Red Oak table and having a heck of a time with the finish. I put two coats of Zinsser Seal Coat on and then sanded to 320. It seemed to be good. I waited a few days to put the poly on, just because. I put a coat of the Poly on and it seemed to raise the grain a bit. I wasn’t to worried about it because I figured a light sanding after each coat would fix it. Well after the third coat it really raised the grain and I was stuck with what felt like the Cascade mountain range. I have since sanded it down to nearly bare wood. Any suggestions on what to do next or name calling for screwing it up would be appreciated. The RO was Rough FAS and I let it acclimate for about a week and a half then milled it. -- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy |
8 replies so far
#1 posted 457 days ago |
I don’t have a quick answer, Bill, but I suspect the accumulated wisdom here will help you out. When I think of raised grain, I think of roughness caused by small hairlike fibers of the wood popping off the surface due to the addition of some kind of liquid. My first question is, how did you clean the wood after sanding the SealCoat? Could that residue be what is showing up on the surface? Is “Cascade Mountain Range” hyperbole, or is the surface really that bad? Maybe you could describe the surface in more detail for us. Over the net to your court… Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#2 posted 457 days ago |
The only thing that comes to my mind is your moisture content is too high in the wood. Now that you are sanding it down to almost bare wood, I’d leave it a couple days and see if you get some grain raise. That would be a sure sign the surface of the wood is still drying as alternate grain patterns should rise a little as it dries. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#3 posted 457 days ago |
Lee, TN, I am going sand it down to the wood and let it sit til I can get a meter. I don’t plan on using the sanding sealer again, maybe some oil then the poly. I just wasn’t sure if the sealer than the poly could have caused me some issues, Thank you both for your replies. -- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy |
#4 posted 457 days ago |
1. Get back to bare wood by stripping or sanding. -- Clint Searl.............We deserve what we tolerate |
#5 posted 457 days ago |
I wil give it a try. Sounds like a good idea. Thanks for the input. -- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy |
#6 posted 447 days ago |
Bill – You have received alot of great tips, so mine will sound somewhat repetitive. The phrase “The smoother the wood, the smoother the finish” rings true. Dust left in the pores can also lead to a rough finish. Grain raising caused by a water-based stain or finish can be reduced by first applying a coat of Wood Conditioner to the bare wood, letting it dry, then sanding off the ‘fuzz.’ Any minor grain raising caused by the water-based finish can be eliminated by sanding between coats with #220-grit sandpaper, then wet-sanding the last coat with #600-grit dipped in lemon oil. I hope this helps. – Bruce Johnson (Minwax spokesperson) |
#7 posted 447 days ago |
I can’t imagine that Seal Coat was a problem, but then…....... -- bill@magraphics.us |
#8 posted 446 days ago |
Thanks all for your input. I ended up sanding it to bare wood and then wiped down with mineral spirits. After that I wiped with a wet towel to raise as much of the grain as possible. I let it dry and than sanded to 800 grit. I then cleaned with mineral spirits again and put four coats of water based Poly on. Used a little turtle wax polishing compound and it came out great. Sorry, but not the best picture.
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
