Use of Fiber Cement Blade
Forum topic by JimAspin2 posted 453 days ago 525 views 0 times favorited 6 replies Add to Favorites Watch
View JimAspin2's profile
JimAspin2
4 posts in 684 days
453 days ago
Topic tags/keywords: question blade
Can a fiber cement blade be used to cut hard woods effectively?
View dbol's profile
dbol
135 posts in 1164 days
#1 posted 453 days ago
I don’t think so. The fiber cement blades have very few teeth and basically tear out chunks of fiber cement.
View DustyRich's profile
DustyRich
12 posts in 484 days
#2 posted 453 days ago
No, fiber cement siding is only 5/16” thick and the blades is basically a modified grinding blade. All you will do to hardwood is burn your way thru veeerrry sloooowly.
View rusty2010's profile
rusty2010
124 posts in 723 days
#3 posted 453 days ago
no. the cut is too rough and chews its way through
-- check, recheck then check again
View Bill White's profile
Bill White
2601 posts in 2126 days
#4 posted 453 days ago
Uhhhh???? Why would ya want to?
Bill
-- bill@magraphics.us
JimAspin2
4 posts in 684 days
#5 posted 39 days ago
I have a flooring saw that takes a 5” blade which I can’t find replacement blades for readily. The fiber blades are available.
Thanks for the assistance all!
woodbutcherbynight
870 posts in 575 days
#6 posted 39 days ago
You could use it if you wanted a burn smell in the shop forever, or a piece that had a “burnt Look” to it. (laughing)
