Brushes for my router?!?
Forum topic by thejosh posted 459 days ago 725 views 0 times favorited 9 replies Add to Favorites Watch
View thejosh's profile
thejosh
563 posts in 740 days
459 days ago
Topic tags/keywords: humor question
Help! I have a thirty year old router that stopped working. Of course, me not being very mechanically sound, I pondered why this lovely Craftsman router wouldn’t turn on when I flipped the switch. I was told by a fellow at work that it was probably the brushes. I just gave him a blank look and finally asked if my toothbrush at home would be an ideal substitute…..He shot back an even blanker look. So, I wandered into my shop today and swooped up the wounded router and pulled out those bumbling brushes and noticed the concave wear they were showing. I went onto Searspartsdirect.com but they no longer have that particular part available…........HUH?? Great, what do I do now?
Frustrated in FoCo
-- "Come to me, all YOU who are weary and burdened, and I will give you rest." ---Matt. 11:28
9 replies so far
View fussy's profile
fussy
964 posts in 1221 days
#1 posted 458 days ago
http://store.eurtonelectric.com. It may take some looking and research, but they will have what you need. You can also try www.ereplacement.com, but Eurton would be my first choice. Good luck.
Steve
View vipond33's profile
vipond33
1311 posts in 668 days
#2 posted 458 days ago
They are supposed to look concave, to match the curve of the commutator on the armature. It may not be your brushes, it may be your switch (most likely) or a break in the wiring. Take it to any service centre, they can tell you what’s up.
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
View Dallas's profile
Dallas
1877 posts in 658 days
#3 posted 458 days ago
You can go to a local electrical motor rebuild shop and they will replace the brushes for you and even make certain the armature and the rest is in good shape.
If it’s nothing more than brushes it shouldn’t cost much more than about $10.
thejosh
#4 posted 457 days ago
Thanks a whole bunch, yous guys! It would make sense that it wouldn’t be the brushes; it hasn’t been used that much.
View dhazelton's profile
dhazelton
832 posts in 467 days
#5 posted 457 days ago
If you have a meter you can use it to check continuity through the switch when you squeeze it. If not the switch there may a broken wire to the motor as stated above. That happened to my Craftsman (Remington?) electric chainsaw—there was a broken wire to the motor that was as thin as a lightbulb filament. I repositioned them back together and put a blob of solder on it and it has held (I couldn’t use a splice, the wire was so thin it wouldn’t support the weight!).
But I would look at this as an opportunity to buy a new Bosch or Milwaukee.
thejosh
#6 posted 457 days ago
Well it’s a craftsman (sears, blech!) but it WAS made in the USA. That’s how you can tell its old. My dad gave it to me a couple years ago. He said he had only used it a few times, and I’ve not used it all that much either. So that’s why I wondered if it was the brushes. I am probably going to have to see if I can take it to some place to get it looked at.
dhazelton
#7 posted 456 days ago
Definitely not brushes if it hasn’t seen much use. You might just need things cleaned and lubed. You could try a bit of contact cleaner for electronics (Radio Shack) shot into the switch and/or lock button. I had a very tiny spider make a nest in the switch assembly of my motorcycle’s turn signal switch. Anything can happen.
I understand wanting to keep things that still work. I have a 1970s Sears hand held power planer I bought for $15 at a yardsale. I always look at the Makita and want it but as infrequently as I use one, it makes no sense buying new if used will do.
View ssnvet's profile
ssnvet
1583 posts in 499 days
#8 posted 456 days ago
Post the model #
I burned up the one I inherited and just replaced it with an e-bay find.
There are several similar, but slightly different…
They share many parts
-- Matt, Pine is fine, but Oak's no joke!
View waho6o9's profile
waho6o9
2921 posts in 748 days
#9 posted 456 days ago
http://www.ereplacementparts.com/
Maybe these folks could help you out.
