Wood drying?
Forum topic by DHaden posted 02-20-2012 02:02 AM 1044 views 0 times favorited 1 reply Add to Favorites Watch
View DHaden's profile
DHaden
77 posts in 2562 days
02-20-2012 02:02 AM
Topic tags/keywords: question tip trick
I have a question about drying a smiall amount of birch. I have a few birch logs from a neighbors tree he cut down this past fall. while in the shop I decided to try something out. I cut a small block about 3”x 3”x7” and put it in the oven @ 200 degrees. Will this work and if so how long should it stay in there? I do not have a moisture meter.
-- Measure once, cut twice.
1 reply so far
View Dallas's profile
Dallas
3599 posts in 2391 days
#1 posted 02-21-2012 02:35 AM
I dry wood in the oven all the time, but I set the temp at 170° or 180°. I usually leave it for 10 to 12 hours for 2X6X24” white oak, Sycamore and Osage Orange. I usually load up both racks in the oven so as not to waste any heat.
Periodically I open the oven door to let the moisture out.
After I take it out and it cools for a day I check it with my little HF moisture meter. If it’s still too wet I put it back in for another cycle.
