How to get repeat thickness
Forum topic by lazyoakfarm posted 02-20-2012 12:04 AM 1331 views 0 times favorited 14 replies Add to Favorites Watch
View lazyoakfarm's profile
lazyoakfarm
144 posts in 2704 days
02-20-2012 12:04 AM
I finally wired up my Grizzly G0453PX 15” planer today. This was the first use of a planer ever. It produced a lot better finish than i ever expected, but I really dont know how to uset it…
Today, I needed to make a repair to a cabinet and needed a plane a piece of wood down to a certain thickness. it was difficult for me to get the exact thickness. is there an easy way to do this other than a lot of trial and error?
Im used to my Incra table saw fence where I can just set it and rip it and its perfect every time…
Thanks
14 replies so far
404 - Not Found
2544 posts in 2876 days
#1 posted 02-20-2012 12:20 AM
There must be a scale on it somewhere… with an indicator on the table telling you what thickness its set at.
lazyoakfarm
#2 posted 02-20-2012 12:34 AM
yes it has a scale, but i wanted it to be more accurate than eyeing the scale. I dont think its possible to eyeball the scale and get it within a 64th? and really want it to be a lot closer than that. Maybe a Wixey digital scale is the answer?
13594 posts in 3248 days
#3 posted 02-20-2012 12:35 AM
when i am doing repeat work
i find which setting is closest
and keep track of the handle position
some planers are 1/8” full turn
some 1/16”
i keep the handle to the same place
(if on top then towards me or away)
if on the side
then up or down
each 1/4 turn is for fine settings
(or 1/8 turn)
that way i can come back to the same place
if i need to move it for other stock
for custom you have to go by measure
till you get it right
i use a block that is the one i want to replicate
and lay them together and feel the differences
View SnowyRiver's profile
SnowyRiver
51457 posts in 3387 days
#4 posted 02-20-2012 12:42 AM
If I am planing a piece down to 3/4”, I would set my planer scale to 3/4 and plane all of the pieces at one time to the scaled 3/4 inch and accept the scale. I have a stop on my planer for various thicknesses. If I am trying to match it to something else, and as I get close to that dimension I start to use a calipers to verify the accuracy. If the piece I am comparing it to is a free piece and not glued to something I will lay the two pieces next to each other on a flat surface to compare thickness after each pass as I carefully plane it to the final thickness.
-- Wayne - Plymouth MN
lazyoakfarm
#5 posted 02-20-2012 12:49 AM
At least I see that I was not totally going abou it wrong. I was having to take a little at a time until I got to the right thickness. I did figure out that turn is about a perfect 1/16 and this helps a lot. I guess the first pass I just need to make sure I am too big rather than too small. DAH…
Has anyone installed a Wixey scale on their planer? I have to use technology to make up for the lack of skill.
View AlbertaJim's profile
AlbertaJim
47 posts in 2336 days
#6 posted 02-20-2012 12:50 AM
I know there are some digital scales available for some planers. Might be Wixey. I’ve never used one, but they should get within the tolerance you want.
-- My Boss was a carpenter
404 - Not Found
#7 posted 02-20-2012 12:53 AM
Don’t know if it will work on your planer but if I know if I have to return to a setting later on in a project, I just draw a line in the dust on the cutter hood to index the position of the handle.
Best thing you can do though is plane all your timber that’s required to be a certain thickness at the same time.
Get a feel for your machine, If one rotation of the handle is an 1/8 inch of a cut, a quarter turn will be 1/32, an 1/8th of a turn will be 1/64 etc.
View tenontim's profile
tenontim
2131 posts in 3651 days
#8 posted 02-20-2012 03:23 AM
I have a Wixey on my 0453. You have to manufacture your own mounting. I think they were originally made for the table top planers. Mine works very well, but I will usually back it up with a set of digital calipers, if I’m trying to repeat or duplicate a thickness.
View skeeter's profile
skeeter
233 posts in 3248 days
#9 posted 02-20-2012 03:34 AM
When planing I always have my 6 inch calipers in my back pocket when planing. Just keep checking. Snowy River has it right.
-- My philosophy: Somewhere between Norm and Roy
View Cato's profile
Cato
701 posts in 3219 days
#10 posted 02-20-2012 12:07 PM
I have the Wixey on my DW745 planer and it works very well.
There have been several times when I had to plane another board to exact thickness. It has a caliper setting that allows you to measure the thickness of a board and then I just plane down to that thickness.
Otherwise I do as Wayne and plane all my boards at the same time. With the Wixey I often don’t have to turn the planer off between boards as I can just watch the digital display as I crank down for each pass on the boards. Saves a bit of time.
View richgreer's profile
richgreer
4541 posts in 2981 days
#11 posted 02-20-2012 03:08 PM
I also have a Wixey on my DeWalt 733. 95% of the time I do not use it. However, when I do need it, it is great to have. If I think I may need to come back and repeat a particular thickness on a piece, but I need to set the planner at other thicknesses in the interim, the Wixey is great.
View Bertha's profile
Bertha
13508 posts in 2600 days
#12 posted 02-20-2012 03:40 PM
^I’ve done what Patron and the others do. I’ll put a piece of blue painter’s tape on my depth gauge as a “target”, then ease up to it. I’ve got a digital meter too and I’ll usually zero it on the desired cut, then sneak up on it. Why? It’s because I’ve forgotten the target thickness before, lol. I can’t rightly forget zero:)
View DS's profile
DS
2855 posts in 2327 days
#13 posted 02-20-2012 04:32 PM
Take the time to calibrate the index scale on your planer. That will get you into the ballpark. Mine is surprisingly accurate, but I rarely can cut directly to the finished thickness. It usually take several passes.
I do like others do and note the handle position for the depth adjustment. I almost always stop the handle at the quarter turns, which handily stops every 1/32” of thickness.
If you need to be VERY precise, you should sneek up to your line on a test piece then run your entire batch of boards.
lazyoakfarm
#14 posted 02-20-2012 04:46 PM
Many thanks for all the help. I don’t think its going to be as difficult as I first thought as long as I go about it the right way. I cannot believe how good the finished product looks. The spiral cutter makes a great finish. The only thing I noticed is that on the softer wood you can see the pattern of the outfeed roller. I was going to loosen the tension on the outfeed roller, but a little sanding is all it took to make it disappear.
