Crosscuting?
Forum topic by Beginningwoodworker posted 82 days ago 341 views 0 times favorited 22 replies Add to Favorites
Beginningwoodworker
310 posts in 108 days
82 days ago
I am wondering how do you guys do your crosscuting? with a miter saw, miter guage on a table saw or a crosscut sled?
-- CJIII Future cabinetmaker
View GaryK's profile
GaryK
8392 posts in 423 days
82 days ago
If it’s short I use my miter gauge (it’s an Incra which I love)
If it’s long ( 5 feet plus) I use a cross cutting sled on my table saw.
I have a miter saw but I never use it.
View Jarrod_Murphree's profile
Jarrod_Murphree
168 posts in 158 days
82 days ago
Rough crosscuts/initial dimensioning is always done at the miter saw; finish cuts are always done at the table saw on my crosscut sled. Although, I did just put a 96t Freud blade on my miter and tuned it up, so I may start making more finish cuts on it.
I don’t own an aftermarket miter guage, but I am thinking about the JessEm.
Hope that helps.
Regards, JM
-- Jarrod, Eagle Nest, NM
View John Fry's profile
John Fry
71 posts in 135 days
82 days ago
For finish crosscutting, I use both my 12” Dewalt slider with a 12” Forrest Chopmaster, and my table saw with an 80T crosscut blade on a very accurate sled.
I break down all my rough lumber on a Craftsman 10” RAS.
-- John, Chisel and Bit Custom Crafted Furniture, www.chiselandbit.com
View bbqking's profile
bbqking
175 posts in 158 days
82 days ago
1. Use your table saw enough that you know it like an old friend. Keep it tuned up so so that it’s square to the world.
2. If you’re cutting a long board, measure and cut rough in the center of the board, to bring it down to lengths you can handle.
3. If your miter gauge allows it, attach an extension to cut longer boards. Again, keep it all square & straight.
I have never used a sled or owned a miter saw. Table saws have been around a lot longer than miter saws.
bbqKing
-- bbqKing, Lawrenceville
8400 posts in 257 days
82 days ago
I primarily use my miter saw for cross cutting but I will also use my table saw with a miter gauge or sled if it happens to be set up.
View brunob's profile
brunob
1369 posts in 604 days
82 days ago
I have an older radial arm saw just for crosscutting.
-- Bruce from Central New York
View EdC's profile
EdC
415 posts in 275 days
82 days ago
For what its worth, if I have to cross cut a rough lenght I use my circular saw for a riugh cut. If you have ever had the chance to see a blade pinched by reaction wood its something you will always remember.
For finish cuts I’ll use a sled or my mitre saw.
-- Ed Collinge- Edmonds, WA.
teenagewoodworker
1889 posts in 203 days
82 days ago
i mostly use the miter saw for my cuts. i am thinking of building a crosscut sled though as i can only cut 6” on my miter saw. if i had a bigger one though i would probably do my cuts on that because i find it easier especially for longer pieces.
3903 posts in 653 days
82 days ago
If I owned a first-class table saw, I would build a good crosscut sled for it, and purchase a good aftermarket miter guage as well.
In reality I have a small, cheap table saw. I do all my cross-cutting and miters on the miter saw. With a good blade I find I can make very accurate cuts.
Beginningwoodworker
82 days ago
Thanks for the tips, I am going to get a 10’’ compound miter saw for on the job use and at home. I am also planning to upgrade my benchtop table saw in the coming year. since I done retire it. I can use my crosscutting handsaws for rough cutting boards and finish them up with a crosscut sled on the table saw.
View benhasajeep's profile
benhasajeep
29 posts in 104 days
82 days ago
For most general cross cutting I now use a radial arm saw. Just bought it last winter. Before that I used a 10” sliding miter saw for boards less that 12” wide. For items wider than that, I use a shop made crosscut sled for 90 degree cuts. I rarely use the miter gauge on my TS.
-- Ben, Living the good life in Maine now (almost, just need to retire in 2 decades time)
View Grumpy's profile (online now)
4658 posts in 286 days
79 days ago
Radial arm Saw for long pieces, Tablesaw sled or mitre guage, OR occassionally the bandsaw OR handsaw. Sometimes the first think I put my hands on. For a neat finish it is hard to beat the table saw sled with a good crosscut blade.
View Joey's profile
Joey
171 posts in 250 days
79 days ago
for narrow pieces i’ll use my miter gauge on my table saw. but for most pieces i use the crosscut sled.
-- Joey, Magee, Ms http://woodnwaresms.com
View lew's profile (online now)
lew
814 posts in 190 days
79 days ago
Sliding compound miter saw for rough dimensioning and then the table saw/miter gauge with an extension for the precision squaring.
I have a very small shop and sometimes the work is too long to be done on the table saw. In those cases, I double check the miter saw, add a sharp blade and make the cuts there.
Lew
View jcees's profile
jcees
425 posts in 234 days
79 days ago
All the above and with a few handsaws too; Japanese ryoba, Disston D8, L-N carcase, etc.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View pyromedic602's profile
pyromedic602
100 posts in 183 days
79 days ago
I use my RAS to cut to rough length before I do anything so my pieces are manegable. I do all finish work at the table saw, Miter guage or sled really depends on what I am cutting, All sheet goods is done entirely at the table saw. Hope this helps.
-- Pyromedic602, free wood is always good wood
View tenontim's profile
tenontim
796 posts in 179 days
79 days ago
Charles, I thought you were a hand tool guy. I use a straight edge and a #11 scalpel for lumber up to 6/4. There’s no tear out that way. :]
-- Tim -- http://tmuli.com
Beginningwoodworker
79 days ago
I am a hand tool guy, but I am planning on doing woodworking for a living so you need power tools.
View WayneC's profile
WayneC
5689 posts in 532 days
79 days ago
Japanese Handsaw, Compound Miter Saw, or Table Saw with Jessem Miter Gauge depending on what is handy and a shooting board if needed…..
Shooting Board and Miter Plane
View Greg3G's profile
Greg3G
624 posts in 520 days
77 days ago
Beautiful set up Wayne.
I use a RAS for my rough cuts. Then it usually the table saw with an Incra miter gage. I find it more accurate and repeatable than my peice of !@#$ Craftsman 10” miter saw. Its a pain to get and keep square and the degree marks are not accurate. It is good for demesional lumber and that’s about it. I have considered getting a good quality 12” sliding mite saw to replace the RAS.
-- Greg - Charles Town, WV
WayneC
77 days ago
Thanks Greg. The miter plane was made by fellow lumberjock Phil Edwards. It is a coveted “Philly Plane”.
View Loren's profile
134 posts in 82 days
76 days ago
A table saw sled is your best bet for an economical
and versatile solution for furniture and cabinetry where
most of your cuts need to be “dead 90”.
I’ve owned all the major tools over the years… even vertical
panel saws and the Festool System. Nothing beats a
sliding crosscut box for versatility except a sliding table
on a nice cabinet saw.
If you do job-site work or even put a lot of molding on your
furniture projects get a miter saw – you’ll save time because
the settings can be changed so quickly.
-- Need help with marketing your business? Look in my profile.
Bookmark And Share This Page
