Bandsaw mitre jig problems
Forum topic by kevinw posted 02-19-2012 10:26 PM 1479 views 0 times favorited 3 replies Add to Favorites Watch
View kevinw's profile
kevinw
195 posts in 3740 days
02-19-2012 10:26 PM
Topic tags/keywords: jig mitre bandsaw box
I do a lot of really little boxes. Up till now I have handcut with mitre box (not chop saw) being desirous to retain my fingers. Got the idea to make a sled mitre jig for my bandsaw as I felt that would be safer than my tablesaw. My problem is that I cannot get it fine tuned enough to suit me. The ends of the joints are always open no matter how I nudge the fence.
I am starting to wonder if the problem is not the fence but blade flex. I am noticing that about every cut is ever so slightly concave. Not sure if you can tell that from the second pix. At any rate, I wonder if anyone has suggestions as to why I am getting the slightly coved shape on the miter?
Thanks for any and all suggestions.
-- Kevin, Blue Springs, MO
3 replies so far
View waho6o9's profile
waho6o9
8191 posts in 2577 days
#1 posted 02-19-2012 10:37 PM
Maybe try a wider carbide blade if possible, or a slower feed rate. Good luck.
View cabmaker's profile
cabmaker
1731 posts in 2809 days
#2 posted 02-20-2012 02:03 AM
Kevin, you re experiencing a problem inherent with the bandsaw. A wider blade with proper tension may help. trying to cut miters with repeatability on a sled with the bandsaw creates its own set of issues. You would almost have to have a sled that adjusts with blade settings,etc. good luck JB
10401 posts in 3648 days
#3 posted 02-20-2012 03:54 AM
Get a Lion miter trimmer or make an angled shooting board.
You will never get consistent results mitering with a band saw,
but a single stroke with a miter trimmer will do it more perfectly
than any saw.
