| Forum topic by SalvageCraft | posted 459 days ago | 909 views | 0 times favorited | 19 replies | ![]() |
459 days ago |
Topic tags/keywords: finish hvlp spray question Hey LJs, I’m picking up a HVLP gun today to finish these shelves I’ve been working on:
I’ve never sprayed on a finish, and am wondering what you guys like to use. Are there any options that have less noxious fumes than the others? Faster dry times between coats? Corrects imperfect joinery? Thanks! -- Jesse -- |
19 replies so far
#1 posted 459 days ago |
Well, shellac does put off some fumes, depending on what you Water-based “lacquers” are pretty clean in terms of fumes but the FYI water-borne finishes are not the same as water-based. |
#2 posted 459 days ago |
Is the back fully attached? If ya can take it off, it’ll make spraying easier. Less blow-back. -- bill@magraphics.us |
#3 posted 459 days ago |
I will take two of the ones that corect imperfect joinery! |
#4 posted 459 days ago |
SalvageCraft, I ask because I need one and am curious as to how & what you decided on. Thanks & good luck with your project! -- Randy-- I may not be good...but I am slow! |
#5 posted 459 days ago |
@DIYaholic: I’m almost ashamed to admit that I went with a harbor freight model. But, It has good reviews, and if it doesn’t work right I can always just return it. http://www.harborfreight.com/high-volume-low-pressure-gravity-feed-spray-gun-66222.html @BillWhite: The back is already glued in place. -- Jesse -- |
#6 posted 459 days ago |
There ain’t no shame in going the HF route! There are some real jems out there. I haven’t reasearch HVLP, yet so I was curious as to your selection. I’m actually about to place an order for their V-Belt for my TS, along with a few other things. I’m also about to travel to Long Island and while there I’m going to stop into one of their stores, as they don’t have a store near me in Vermont. Looking forward to seeing your “Finished” project! -- Randy-- I may not be good...but I am slow! |
#7 posted 459 days ago |
Since you say that you haven’t sprayed before, put your project in storage for a while so you can do a lot of practicing with different finishes. If you have a true HVLP rig (with turbine) it’s just a matter of learning how to thin your finish (if necessary) and set up the right tip and orifice. If you got an HVLP conversion gun (runs on an air compressor), you’ll need to practice thinning, setting the best air pressure (40 psi seems to work for me), and experimenting with the tips and orifices until you get good results. If you’re usig a compressor, does it have enough capacity to run HVLP? I have a 20 gal tank and that does ok, but bigger would be better. -- Adversity doesn't build character...................it reveals it. |
#8 posted 459 days ago |
Speaking of V-Belts…
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#9 posted 459 days ago |
I am also looking forward seeing how it works for you… I thought you were going with the one that looks the one Rockler sells… which I understand are very good. -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#10 posted 459 days ago |
SalvageCraft you should of said earlex, there is a very knowledgeable and helpful earlex guy comes on here, LOL. He could be alot of help with the right tip and orifice for various finishes etc. Leaving the back off was a good point, as well as ventilation. A fine mist might prove to be a breathing and eye hazard, spraying into those shelves you should realize that some of that mist will be carried back toward you. Not trying to scare you just point out that what is a good finish for your project is not a good finish for your lungs, the mist will contain particulate misted finish not just evaporating vapors, if that makes sense. Think about ventilation for your health, think about the over-spray. I realize that most of us, me included don’t have a dedicated spray booth, but a fan suitable for the product being sprayed, perhaps a muzzle (spelled respirator with suitable filter cartridge) combined with suitable eye protection is a minimum valid consideration. I’m a newbe to the HVLP myself but have been researching a bit, I would rather be safe than sorry. |
#11 posted 459 days ago |
I have had wonderful results using cheap Harbor Freight spray guns. I have used mine to spray oil based paint (rustoleum) on about a dozen doors to refinish them. Doors tend to pick up greasy finger marks and turn yellow when people smoke in their house. I personally can’t stand latex paint and love the durability and easy cleaning of oil based paint for doors, bathrooms, kitchens, and garages. At first I had read that I should thin out the paint a lot and I just wasn’t getting enough coverage. I switched to using about 10% mineral spirits to 90% paint (just eyeballed it) and it came out great. Other doors I had seen that were painted over with a roller or brush looked terrible. These cheap hollow doors with fake wood grain already have enough things going against them. Using the harbor freight spray gun made it look like new again. I ended up with a really flawless finish. I was so impressed with the pint sized one that I picked up a quart sized one as well. I paid less than $15 each. I haven’t tried using any other finishes with them yet, but the rustoleum slightly thinned out has exceeded all of my expectations. Practice on some scraps until you get everything dialed in and spraying well. -- "To do is to learn. A brilliant man once said that... I think he had a beard, too." - Joe Burns, HTML Goodies |
#12 posted 459 days ago |
The gun you purchased is a good gun for the money. It will handle lacquer shellac and alkid enamle very well. -- Richard, North Carolina, http://graywolfwoodworks.wordpress.com/ |
#13 posted 459 days ago |
My go to finish is zinsser sealcoat (dewaxed shellac) followed by crystalac super premium. I spray in my kitchen with a box fan and furnace filter in the window. Works great. -- He who dies with the most tools... dies with the emptiest wallet. |
#14 posted 459 days ago |
Update – I went with minwax PolyOne. Thinned to about 90% with mineral spirits and have the first two coats on. So, WOW. I’m never gonna brush on poly again after this! For both shelves together, each coat took about 5 minutes, including time spent mixing the finish and cleaning out the gun after use. I was able to put on the second coat after about 45 minutes. Based on my past experience with brushing on poly, each coat would have easily taken me an hour and a half, including setup and cleanup time. Then about 4 hours minimum to dry between coats, due to the thickness of each layer. I don’t mind doing twice as many sprays to equal the coverage of brushing on. I figure I’ll save at least a half day’s labor altogether here, and gain at least a day of the shelves not taking up space in the shop to stain :) Also, I don’t have great ventilation, but just opened up the basement windows for about 15 minutes during and after spraying. I was pretty sure the fumes would be worse than brushing, but they were actually much fainter! (: Happy woodworker :) -- Jesse -- |
#15 posted 459 days ago |
Good to hear. Glad it went well for you! You should consider a respirator with the proper cartridge filter!!!!!!!!!!! -- Randy-- I may not be good...but I am slow! |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15801 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
