Craftsman contractor TS upgrade
Forum topic by Mainiac Matt posted 02-19-2012 03:12 PM 897 views 0 times favorited 3 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
8044 posts in 2326 days
02-19-2012 03:12 PM
I bought this saw on clearance years ago and it has done well by me.
The fence works well and I have other means available to cut large sheets, so I can’t really justify the expense of a cabinet saw.
But the cast iron “skeleton” extensions have always bothered me, as they sometimes catch a corner on a bowed panel.
So I got the idea to bond a piece of laminate (left over from an ancient project) to make them solid top.
The mounting holes in the winged provided some wiggle room, but just ~1/32” shy of that needed to drop the wings to make the new laminate top flush. So I drilled out the mounting holes 1/16” larger and bingo!
I attached the laminate with spray contact adhesive and it stuck tightly.
The one problem was that I could no longer get a ‘C’ clamp through the webbing to suck the center section up perfectly flush, but it’s very close. (any body got a 13” deep clamp I can borrow for the weekend?)
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
3 replies so far
View DIYaholic's profile
DIYaholic
19620 posts in 2673 days
#1 posted 02-19-2012 03:37 PM
Have you tried a clamping cawl? A board with a slight convex bottom.
Mainiac Matt
#2 posted 02-19-2012 03:46 PM
No… But I like the way you think!!
DIYaholic
#3 posted 02-19-2012 03:52 PM
I had a good idea, who’d a thunk it? I had another good idea a while ago, but it died of loneliness!
Let us know how it works out.
