multi-tool workstation built from old desk
Forum topic by Mainiac Matt posted 02-19-2012 03:10 AM 6647 views 2 times favorited 8 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
8029 posts in 2323 days
02-19-2012 03:10 AM
Look! Up in the shop! It’s a bench, no it’s a jointer… and a drill press, and a disk and belt sander, and a planer and a grinder….... It’s super bench!
I salvaged this old solid wood desk years ago from a job site…. it has a 1” solid hardwood top, so I fabricated a tray on casters and used it as a mobile bench for a while
Next, I found an old Craftsman jointer at a garage sale (little did I know at the time how old) and brought her home on the cheap. These oldies were sold without a stand, and this one had a falling apart 2×4 frame, so I cut the top of my desk/bench and lowered the right side, and then removed the large file drawer and mounted the moter and plumbed DC in it’s place. The motor shaft extended out both sides, and one evening at Woodcraft I saw an 8” sander plate and had an epiphany.
Then I decided to permanently mount my 12” bench top planer with the feed path running the long way underneath. This planer is a real sniper, so I mounted a 12” melamine shelf as an adjustable feed ramp.
A couple years later I aquired a bench top drill press and built a nice table for it. She’s mounted a little higher than I’d prefer, but I’m 6’ tall, so I can get buy with it.
Added a cheap China vise, in which I can mount my 4×24 belt sander…
Lastly, I mounted a cheap bench grinder that was looking for a home
There’s a power strip mounted to the back and the bench.
I use the remaining drawers for drill bits and tools specific to the mounted machines.
I can process a 7’ board through each station without moving anything
Hear’s a final pic ….
I hope this may help spark some creative ideas out there. Old desks are readilly available and can make a decent economy workstation.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
8 replies so far
View chrisstef's profile
chrisstef
17380 posts in 3001 days
#1 posted 02-19-2012 03:16 AM
now thats using space to the fullest. Chock full of good stuff. I think im going to head into space problems sooner than later so im always on the look for space savers, i dig it.
Mainiac Matt
#2 posted 02-19-2012 03:24 AM
I recently stripped down the jointer and cleaned up the ways, re-adjusted the outfeed table and blade height, etc….
The jointer motor mount vibrated the bench quite a bit, so I added a Harber Freight link belt, and it cut the vibration roughly in half.
I borrowed a 36” Starret straight edge from work and was tickled pink to find that the infeed table is parallel to the outfeed table within two sheets of paper (I could slide one sheet under the straight edge, but not two).
I did some research on the jointer on one of the old tool web sites and found out that the date of manufacture was circa. 1938!!
:^O
It’s an oldie, but a goodie
View Loren's profile
10377 posts in 3643 days
#3 posted 02-19-2012 03:38 AM
Those jointers were made by Walker Turner. The fence you have
is the better one, a really well-designed jointer fence that holds
its setting. There’s a rare swing away guard to keep your eyes
out for on a similar jointer… the guard is worth a pretty penny
to Walker Turner fiends.
View redryder's profile
redryder
2393 posts in 3097 days
#4 posted 02-19-2012 06:32 AM
I like your forward thinking. Is there a coffee maker on board….............
-- mike...............
Mainiac Matt
#5 posted 02-19-2012 02:50 PM
“Is ther a coffee maker on board”
Not a bad idea. :^)
View BradB's profile
BradB
3 posts in 2892 days
#6 posted 02-20-2012 02:49 AM
That’s the Swiss Army of workbenches! Cool
View TelescopeMaker's profile
TelescopeMaker
77 posts in 3015 days
#7 posted 02-25-2012 03:48 AM
I think you just solved a problem I was having with my new drill press. I designed up a whole flip top thing with my planer that was going to be a beast to use, and way too tall. Yep, this gives me way good ideas.
Thanks a million
-- Telescope Maker, Woodworker, Brewer, Gizmologist, Gardner, Lawn Mower
View Dusty56's profile
Dusty56
11819 posts in 3683 days
#8 posted 03-28-2012 12:27 AM
Very impressive work center : )
