Powermatic 54A pulleys
Forum topic by Dusty56 posted 02-18-2012 06:52 PM 909 views 0 times favorited 7 replies Add to Favorites Watch
View Dusty56's profile
Dusty56
11814 posts in 3559 days
02-18-2012 06:52 PM
Topic tags/keywords: question jointer powermatic 54a
Hi folks,
To those of you that own Powermatic 54A jointers , I am wondering what size pulleys are on your machines.
I purchased a used jointer and the cutterhead and motor pulleys are the same small size…roughly 2.5”
Is this correct ? Thank you : )
7 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2546 days
#1 posted 02-18-2012 08:51 PM
Dusty, I don’t own a Powermatic jointer but I do have an old Craftsman jointer and they are the same size on it. I think that is pretty common.
View tenontim's profile
tenontim
2131 posts in 3615 days
#2 posted 02-18-2012 10:54 PM
The one on my motor is 4.5” and the one on the cutter 2.5”.
Dusty56
#3 posted 02-19-2012 06:11 AM
Grandpa , thanks for your input , but I addressed my question to owners of the 54A Powermatic jointer,
I have owned other brands and they all had larger pulleys on the motor…my whole reason for asking in the first place. The cutter head seems to be spinning so fast I don’t want to burn up the bearings.
tenontim
#4 posted 02-19-2012 12:48 PM
Actually the larger pulley on the motor is going to make your cutter head spin faster than the motor, approximately 6210 rpm, with a 3450 rpm motor. You have a 1.8 overdrive ratio.
Dusty56
#5 posted 02-19-2012 05:49 PM
Wow , I thought the larger pulley would slow it down. Thanks for the info , Tim : )
Grandpa
#6 posted 02-19-2012 10:12 PM
Tim is correct. The driver is larger so you get more RPM out of the cutter head. I have Craftsman jointers and they use the same pulleys on each shaft.
Dusty56
#7 posted 02-19-2012 10:31 PM
Thanks for the verification , Grandpa : )
