Removing yellow glue
Forum topic by skeemer posted 02-18-2012 05:38 PM 1901 views 0 times favorited 10 replies Add to Favorites Watch
View skeemer's profile
skeemer
95 posts in 2359 days
02-18-2012 05:38 PM
I’m finishing up my first project and I had quite a bit of squeezeout in my joints (using Titebond II). I’m having a hell of a time removing it now as I prepare to finish. Trying to pop it off with my utility knife is pulling some wood fibers out, and sanding with 120 grit doesnt seem to have any effect other than removing the adjacent wood. Too small to reach in with any sort of sander.
Any suggestions? The worst spots are inside 90 degree corners in tight spaces. Thanks!
10 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2670 days
#1 posted 02-18-2012 09:13 PM
vinegar is supposed to make it release but you run the risk of loosening the joint also. The best thing is to remove it during assembly while it is fresh but you are a little late for that. Good luck. If you choose to not wash it with a rag and some fresh water on assembly you might try tape then you can remove it and take the glue with it.
View xwingace's profile
xwingace
228 posts in 2583 days
#2 posted 02-18-2012 09:14 PM
You might try a square profile micro-rasp, I’ve had good luck with them trimming up inside tight corners.
-- I'm not as good as I once was, but I'm as good once as I ever was.
View chrisstef's profile
chrisstef
17378 posts in 3001 days
#3 posted 02-18-2012 09:15 PM
I like to use a card scaper on the glue just before it totally hardens. The rest comes off with sanding.
View premieretreeservices's profile
17 posts in 2293 days
#4 posted 02-18-2012 10:09 PM
Soaking the glue in boiling water for a couple minutes will likely soften it enough to scrape off. You’d have to try hard not to get too much on the wood, but it’s pretty effective. Applying water is also less risky than applying chemicals if you’re worried about ruining your wood.
-- Premiere Tree Services Network: http://www.premieretreeservices.com/
View Lee Barker's profile
Lee Barker
2170 posts in 2845 days
#5 posted 02-18-2012 10:25 PM
A well sharpened scraper and some patience will remove it. Your ears will tell you the difference between cutting hardened glue and cutting wood.
Absent that, can you get a sharp chisel in there?
Kindly,
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#6 posted 02-18-2012 10:37 PM
That’s why a finish my project before I glue it together. Live and learn. If plywood is going into a rebate or dado I mask off the ends of the plywood that will go into the rebate or dado with blue tape so the glue can adhere afterwards.
View Dallas's profile
Dallas
3599 posts in 2481 days
#7 posted 02-18-2012 10:38 PM
I have an old old old paring chisel I cut down that works well for stuff like that. I keep it sharpened nicely and I suppose it will still do some paring, but it use to be an inch wide and now it’s only about 5/16” wide.
404 - Not Found
2544 posts in 2963 days
#8 posted 02-18-2012 11:08 PM
A sharp chisel, a light touch and patience.
View Lifesaver2000's profile
Lifesaver2000
551 posts in 3107 days
#9 posted 02-19-2012 02:51 AM
If you use a heat gun or an old hair dryer, you can soften the glue enough to scrape it loose. Don’t over heat because you can actually loosen the glue joint.
skeemer
#10 posted 02-24-2012 04:54 PM
Thanks for all the replies everyone! I chiseled off what I could but a lot of it was set in pretty good. With the finish on, you can’t really see it but I know it’s there. There are a number of other flaws in it as well, but I do plan to redo this at some point in the future once my skills are honed a bit more. Anyways, I’ll be posting some pictures of it later today. I appreciate all the help!
