Best place to get 'T' track
Forum topic by Mainiac Matt posted 02-18-2012 02:09 AM 21845 views 4 times favorited 30 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
8512 posts in 2505 days
02-18-2012 02:09 AM
I’ve got three shop projects cooking that require extruded aluminum T track….. Same type stuff available at Rockler.
I’m also interested in the profile that has the measuring tape slot for use with a stop block on a fence.
I just can’t bring myself to pay $30 for one 4’ piece.
-- I yam what I yam and that's all what I yam
30 replies so far
View madts's profile
madts
1872 posts in 2516 days
#1 posted 02-18-2012 02:14 AM
You and me both. That stuff is way to expensive
-- Thor and Odin are still the greatest of Gods.
View waho6o9's profile
waho6o9
8487 posts in 2753 days
#2 posted 02-18-2012 02:17 AM
I might add make sure you can use normal 5/16 or 1/4 bolts for jig making as well. That proprietary nonsense is a bit much.
http://www.eagleamerica.com/prod_detail_list/miter_track_t-track
View hhhopks's profile
hhhopks
654 posts in 2553 days
#3 posted 02-18-2012 02:18 AM
Me three.
-- I'll be a woodworker when I grow up. HHHOPKS
View DamnYankee's profile
DamnYankee
3312 posts in 2738 days
#4 posted 02-18-2012 02:22 AM
The best prices I’ve found is Hartville Tools at hartvilletool.com
-- Shameless - Winner of two Stumpy Nubs Awards
View HorizontalMike's profile
HorizontalMike
7770 posts in 3090 days
#5 posted 02-18-2012 02:32 AM
I buy from 80/20 INC.. Their 1in T-track is superb and reasonable.
http://www.8020.net/T-Slot-1.asp
View bondogaposis's profile
bondogaposis
5055 posts in 2527 days
#6 posted 02-18-2012 02:36 AM
This is the cheapest I’ve found. http://www.ttrackusa.com/
-- Bondo Gaposis
View MrRon's profile
MrRon
5149 posts in 3420 days
#7 posted 02-19-2012 10:01 PM
I found McMaster-Carr to have the best prices; example: 48” T-track for 1/4” bolt- $11.55. You have to pay S&H, but you also have to with any other companies.
View BigFoot Products Canada's profile
711 posts in 3569 days
#8 posted 02-19-2012 10:13 PM
Cheapest T-Track = Use a Keyhole Router Bit in your Router.. I do it all the time and it’s awesome.
Make your own in PLYWOOD or Acrylic, then cut your track to whatever width you want and glue it into your project. If your project is already made out of PLYWOOD, just cut the slots right where you want them. If you want a WIDER slot than 1 pass makes, just move it over a fraction & make another pass… :)
Mainiac Matt
#9 posted 02-23-2012 07:37 PM
I’ve considered that David….
The Rockler bit I’ve seen, only cuts the slot…. you first have to make a pass with a 3/8” bit.
The bit you show, looks like it does it all in one pass.
Have you used that bit? If so do you rout tha slot first with a straight bit? or do you hog it all out in one pass?
Mainiac Matt
#10 posted 02-23-2012 07:39 PM
Do you have a McMaster p/n Ron…
I’ve been jon their site a couple times and all I’m seeing is the four sided stuff that is used to build machine frames.
View rdjack21's profile
rdjack21
268 posts in 3103 days
#11 posted 02-23-2012 07:47 PM
It looks like this bit T-Slot Bits
-- --- Richard Jackson
View Bobsboxes's profile
Bobsboxes
1369 posts in 2840 days
#12 posted 02-23-2012 07:50 PM
I like to wait untill Rockler has it on sale as a kit, I think there is one 4’ piece and a bunch of hardware for 14.99. Been a couple years since I bought some, but it has worked for everything I needed. As for a great deal, just let me buy it first and then it is sure to be on internet the next day for half of what I payed. Thanks, Bob
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View peterbb's profile
peterbb
37 posts in 2463 days
#13 posted 02-23-2012 08:52 PM
That CMT bit looks excessively huge.
Lee Valley has some for 1/4-20 T-bolts that are much smaller:
http://www.leevalley.com/en/wood/page.aspx?p=51233&cat=1,46168,46176
-- Peter
View gfadvm's profile
gfadvm
14940 posts in 2866 days
#14 posted 02-24-2012 03:25 AM
I have a similar router bit that doesn’t have the cutters on the shaft. I cut a 1/4” dado on the table saw and then rout the t track. This method uses the dado to guide the cut so you don’t have to use a jig or straight edge.
#15 posted 02-24-2012 03:37 AM
The bit is called a “KEYHOLE ROUTER BIT” not a T-Slot Bit.
and yes it cuts the groove all in 1 pass.
Here’s 1 at Home Depot
Here’s more at WOODCRAFT
If you just do a GOOGLE search for “buy keyhole router bit” you’ll find lots of links..
showing 1 through 15 of 30 replies
