Blower cfm
Forum topic by bj383ss posted 02-17-2012 12:03 AM 1028 views 0 times favorited 2 replies Add to Favorites Watch
View bj383ss's profile
193 posts in 2293 days
02-17-2012 12:03 AM
Hello all. I recently acquired a free blower motor from a house HVAC. The blower has no markings. The motor is a 1/3 hp general electric. It has 3 speeds. Based on the size of the squirrel cage fan I found some where on the net that showed a cfm number. Can’t remember where I found it. Anyways it said mine was 1200 cfm. Do you think this is on high speed or low speed?
Thanks for your help. I used it to make a shopmade air cleaner.
2 replies so far
View crank49's profile
4030 posts in 2902 days
#1 posted 02-17-2012 01:07 AM
That would most likely be high speed.
If you make a shop air filter using that fan you might not see that much flow.
Those squirrel cage fans don’t have much capacity for pressure.
For a good air filter you need the very dense .5 micron type filters and they will stall the flow down to a much lower level. Should still work well though.
What it won’t do very well is serve as a blower for a dust collector or a cyclone. Those applications require too much pressure.
View hhhopks's profile
650 posts in 2308 days
#2 posted 02-17-2012 01:21 AM
Crank49’s answer got my vote.
-- I'll be a woodworker when I grow up. HHHOPKS
