Does it pay to buy premium mortise chisels
Forum topic by Chipy posted 02-16-2012 09:09 PM 1056 views 1 time favorited 3 replies Add to Favorites Watch
View Chipy's profile
Chipy
374 posts in 2558 days
02-16-2012 09:09 PM
Topic tags/keywords: resource tip question
I just recently picked up a Grizzly Tenon jig on CL for $30 and bought a Shop Fox Mortiser.My question to the exsperienced mortise cutters is, does it pay to buy premium mortise chisels? I have seen the 3 and 4 piece sets for as little as 30 to 40 dollars and “Premium” bits as much as 26 to 40 a piece.Are the premium bits that much better or should save my money and buy the economy sets? Thanks for your info Chipy.
3 replies so far
View Scot's profile
Scot
344 posts in 3361 days
#1 posted 02-16-2012 09:30 PM
The premium do hold an edge longer. That said, the set that came with my Shop Fox mortiser are still good after five years but I only use them on soft woods. I have a premium set that I use on hard woods.
Either way you will have to sharpen them, so I recommend you get a mortise chisel sharpening stone. Unless you can afford to buy a new set every time they get dull.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View Bertha's profile
Bertha
13521 posts in 2658 days
#2 posted 02-16-2012 09:34 PM
I’m not sure I know. I bought a JET mortiser and although I knew it came with bits, I ended up buying a set of “nice” bits at the same time. The nicer ones are a little bit nicer looking but I really can’t say that they work any better. Maybe time will tell but I’d wait to upgrade if you’re happy with the cut. Good luck!
View tenontim's profile
tenontim
2131 posts in 3709 days
#3 posted 02-17-2012 12:59 AM
I do a lot of mortising with the cheap chisels. I’ve had the same three chisels for about 10 years. I do own a sharpening stone for them, and use it regularly. Like any other tool, if you keep it sharp, it works better. So before I start a new project I sharpen the chisel that I’m going to use and have no problems. Like already mentioned, the high dollar ones may keep an edge longer.
