Butt-jointing plywood with glue and screws
Forum topic by Brett posted 457 days ago 4540 views 0 times favorited 15 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 848 days
457 days ago
I need to butt-joint two pieces of plywood with glue and screws. Will plywood tolerate having a screw driven into its edge (even with a pilot hole), or will the plywood split? What about butt-jointing normal wood, with the screw driven into end grain? How well will that hold up?
-- More tools, fewer machines.
15 replies so far
View SnowyRiver's profile
SnowyRiver
45610 posts in 1646 days
#1 posted 457 days ago
I guess I am not sure if you are screwing it on the face, or the edges. I use a pocket hole jig for 3/4 ply. It seems to work fine. I havent tried to glue ply thinner than that though.
-- Wayne - Plymouth MN
View crank49's profile
crank49
2276 posts in 1136 days
#2 posted 457 days ago
Butt joints have almost no strength, even if the plywood does not split.
Could you possibly rabbit the edges so you would have a lap joint?
Or, as an alternate, this is a good application for biscuit jointery.
I think they make special screws for pocket hole joints in plywood that have flat heads to reduce splitting.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
14844 posts in 2384 days
#3 posted 457 days ago
It really depends on the overall situation.
I have used butt joints, with screws going into the edge of plywood many times on shop furniture, jigs, etc., and they work perfectly fine. However, I would not use that type of joint to support a great deal of weight, such as a shelf for a planer, unless the overall structure included some other type of reinforcement. I’d give pretty much the same advice for solid wood as well.
View BobM001's profile
BobM001
390 posts in 496 days
#4 posted 457 days ago
Multiple offset biscuit joints in a “saw tooth” pattern. Or if you have the room and your biscuit jointer blade is SUPER sharp stack two at each position with the width of a biscuit between each one. The “side grain” of the plys will glue OK, it’s the end grain where the issue lies.
-- OK, who's the wise guy that shrunk the plywood?
View Mosquito's profile
Mosquito
2754 posts in 458 days
#5 posted 457 days ago
I’m not too knowledgeable when it comes to plywood, so I have to ask…
Is the “side grain” of the plywood the edge of the plywood that is running parallel to the grain (typically the 8’ sides on 4×8?) That’s my guess, but was just making sure…
-- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods
View richgreer's profile
richgreer
4474 posts in 1240 days
#6 posted 457 days ago
I don’t think you are ever going to get a real strong joint when you put 2 pieces of plywood together. However, in some applications a real strong joint is not needed.
If I wanted a strong joint with plywood, I would run both pieces into a groove in a corner piece of solid lumber.
#7 posted 457 days ago
You can also, if you have room, use a glue block to support the joint. (For example, a piece of 3/4×3/4 stock running the full length of the joint.)
Brett
#8 posted 457 days ago
The diagram below shows a rough picture (it’s a jig for sharpening chisels on a bench grinder). The bottom and side pieces are either plywood or real wood. The gray thing across the top is threaded rod. There are other parts, but I’ve left them out.
If I use plywood for the two uprights, I’ll need to drive screws up through the base into the edges of the plywood. I can use real wood if plywood won’t work. In either case, I can probably cut some dados for the bases of the uprights to give them more stability.
Or, maybe I should mount the uprights on the sides of the base and drive the screws horizontally through uprights into the base:
The base is a big slab of 2”x12” pine, so this design would require driving screws into the end grain of the base.
12048 posts in 1507 days
#9 posted 457 days ago
if you have the room for it
a third piece as a brace
will keep the sides from ‘wobbling’
loosening the joint
as in box construction
or cabinets
View NiteWalker's profile
NiteWalker
1467 posts in 742 days
#10 posted 457 days ago
Brett, I would go with option #2 above, but take it a step further and rout a very shallow 1/16” rabbet on the end pieces. Not for additional strength, but to make assembly easier. With plain butt joints, things like to slip around when glue and clamps are applied.
Predrill for the screws, glue it up and everything will work great. Just use long thick screws.
If you go with option 1, I’d definitely bring the ends in about 1/2” each and cut 3/8” or even 3/4” dadoes since you’re using 2×12” pine.
Brett
#11 posted 457 days ago
NiteWalker, if I go with option 2, should the rabbets in the end pieces be made where the base touches the end pieces? (Sorry for the beginner-level question.)
View Jimmy0x52's profile
Jimmy0x52
31 posts in 466 days
#12 posted 457 days ago
Kreg Jig.
It’s made for this specifically.
-- Jimmy, Austin, TX - Software developer by day, woodworker by night
NiteWalker
#13 posted 457 days ago
Brett, yep, rabbet the end pieces where they attach to the base.
And the kreg jig would work better for option 2 as well. Definitely go that route if you have one.
crank49
#14 posted 457 days ago
I thought you were talking about a true butt joint, two pieces of plywood butted end to end.
The right angle connection you are planning should be fine.
If you need extra holding power for that joint you can put a large (3/4” to 1”) dowel through the “end-grain” piece in the path of the screw and about an inch away from the end. That makes a very strong joint.
I believe I’d go with your first example and make the base piece about an extra 1” long so the screws would not be so close to the edge.
View Loren's profile
4870 posts in 1813 days
#15 posted 457 days ago
Plywood screwed through the edge doesn’t perform as well
as most solid wood in screwholding, especially near the edges
where the plywood can split if the joint is stressed.
Confirmat screws offer the best performance in this sort
of application. The holes are best drilled with a special
bit.
