Angles
« back to Hand Tools forum
Forum topic by madts posted 02-16-2012 03:05 AM 1214 views 0 times favorited 8 replies Add to Favorites Watch
View madts's profile
madts
1862 posts in 2365 days
02-16-2012 03:05 AM
Topic tags/keywords: question jig tip trick
All: I like to make angle cuts on the band and table saws. What is the best tool to transfer say a 60.5 deg angle to the saw. I have a small protractor and a bevel. I always have to peck and chip to get it just right. I would like, just for once to hit it right the first time.
Any and all help would be appreciated.
Madts
-- Thor and Odin are still the greatest of Gods.
8 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2701 days
#1 posted 02-16-2012 03:28 AM
Use a machinist’s square. It has a protractor built on it. I have a Starrett and I really like it. Just turn the blade to the right setting and place it on the wood then draw the line. Done. I think they are about $40 or so. In my area (lots of machine shops) they are plentiful in pawn shops.
View Loren's profile
10476 posts in 3674 days
#2 posted 02-16-2012 05:18 AM
Digital protractor. Bosch, Wixey, other brands.
Bora Angle Master Duplicator. Festool Miterfast.
View gfadvm's profile
gfadvm
14940 posts in 2716 days
#3 posted 02-17-2012 03:02 AM
Those digital angle gauges work great and are cheap.
View hhhopks's profile
hhhopks
651 posts in 2403 days
#4 posted 02-17-2012 03:07 AM
I back Loren & gfadvm. Those digtal angle gauge are great.
I use it on my table saw all the time. I trust it enough where I don’t even use a square anymore.
Everytime I check the prices on these things it gets cheaper and cheaper.
I probably end up getting another one.
-- I'll be a woodworker when I grow up. HHHOPKS
View Popsnsons's profile
Popsnsons
387 posts in 3007 days
#5 posted 02-17-2012 03:13 AM
Check out this one. It looks like it would work for you and only $20
http://www.leevalley.com/US/wood/page.aspx?cat=1,42936,50298&p=69055
-- Pops ~ In So Cal...
View rance's profile
rance
4258 posts in 3186 days
#6 posted 02-17-2012 03:17 AM
Incra 1000SE. Actually, the v120 would be a huge step up from a factory miter gauge. These have a fractional vernier so you can get fractions of a degree.
madts
#7 posted 02-17-2012 03:19 AM
Thanks for the input. I will let you guy’s know which way I went.
View vonhagen's profile
vonhagen
538 posts in 2390 days
#8 posted 02-17-2012 07:32 AM
i use all starrett layout tools and a router on a pivot point for large radius work and 1/4 inch mdf templates and a festool ts 75 to cut out my angled patterns the clamp my patterns to to my stock and use a large pattern bit with upper bearing with turnaknives to make perfect copies, ive got a 5000 dollar altendorf mitergauge on the slider but the festool is much faster and wherever you put that rubber edge thats where it cuts. so basicly a 700 dollar festool plunge saw makes more accurate angle cuts than a 50,000 dollar altendorf saw. on the bandsaw i use a pivot point just like the router but in reverse and can spin perfect radius work up to a certain point. i always use patterns so if i screw up its only mdf not expensive material
-- no matter what size job big or small do a job right or don't do it at all.
